I brought and fitted an upc brake kit http://www.ebay.com.au/itm/330mm-ROT...item4850f14bc1
to fit 330mm rotors of a fellow ford forums member to my au today however my au 17s wont fit over them ![]() |
And is it worth fitting the rear 303mms i got in the kit to replace my 287mm rear brakes? or would territory rears be better to match the fronts?
![]() Join Date: Aug 2005
I just put on a set of 322mm fronts and 328mm rears on my AUIII XR6, the pics are in my Silver build.
What sort of Rotors are you using on the front? |
no idea mate they are obviously rear rotors of another car but not sure which ones hopefully there not made in house as id rather buy locally pretty sure its just regular ba brake pads i buy just unsure on rotors
to confirm ba xr8 wheels fit over these brakes fine and they work surprisingly well for what they are. Having bigger ba calipers and pads helped aswelll im sure.
after doing some hard stops tonight they are definatly a **** load better then standard brakes some territory rears should see this firm up abit more aswell as some braided lines
Good on ya matey.
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
Depending on the kit
Are the hubs adapters gold or black?
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
yeah I have the kit I haven't fitted yet, as its part of a series 1 to 2-3 upgrade
the rotors seem to be rears as they have the hole for the hand brake adjustment could be brembo 4 pot rear dimensions tell me do you have rotor to calliper clearance problems? |
The hub adapters on mine were gold. Nope No issues roberts straight bolt on only issue I had was my au 17s were to small just fouled up by like 5-10mm but ba xr mags fixed that yeh there definatly rear rotors that fit on the fronts far as I've been able to deduce I believe there protex brand calipers same as FORD FPV GT-P 5.4L V8 R/H 2002 On Rear Protex Disc Brake Rotors DR507A these on eBay but with slots cut in them by UPC As UPC 507 is the number UPC give on there eBay ad could be wrong tho
