Old 01-01-2006, 10:59 PM   #1
sam-efxr6
sam-efxr6's Avatar
Default Climate Control
I have a 96 ef xr6 and wanted to know if it has the wiring etc. for the climate control, because my mate has one he wants to get rid of cheap.
sam-efxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 11:08 PM   #2
John_LS1
the engine bay *might* have the wiring. i know the ED's do as i converted a XR6 wagon and only needed the dash loom and heater box plus various sensors and climate module. if you have the engine loom already then its pretty easy to do.
Old 01-01-2006, 11:15 PM   #3
InitialD
Low and Loud
InitialD's Avatar
EF and EL didnt get the wiring like we discovered on EB2/ED's. Ford started making different engine looms. Discovered this with the NF wreck and when i looked at EFFALCONS car after suggesting the same thing. ;)
So sorry dude it wont work unless you change your engine / dash and maybe body loom. Isnt worth it really IMO unless your really wanting it like I did
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 11:34 PM   #4
EDXR6T
buy a ghia:P
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 12:01 AM   #5
JouMa
like i did
JouMa is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 12:45 AM   #6
spope
spope's Avatar
You did it the hard way, really :p
You have to add the wires for the ambient temp sensor and that should be it on an EF, in terms of the engine bay.
ECT it gets from the ecu, you will need to install the sun load sensor and the cabin sniffer motor, and it would probably be easiest to hack apart a Fairmont dash loom to get all the wires and connectors.
That's how i installed it in the EA, really not that difficult, hardest part is getting the heater box in + out.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 01:15 AM   #7
InitialD
Low and Loud
InitialD's Avatar
And your "attempt" to convert to climate control worked? i seem to remember it not working right lol :P
Old 02-01-2006, 01:25 AM   #8
XR Martin
XR Martin's Avatar
Its not that hard, ive done it to my ED. Mostly time consuming.
If you can get the complete heater box and dash from a Fairmont youve got everything you need apart from the ambient sensor.
A few people have done it to EF/ELs on Fordmods.com and I dont remember anyone needing to change the engine bay wiring. Certainly didnt need to do it to my ED.
2004 BA wagon RTV project.
Old 02-01-2006, 12:49 PM   #9
sam-efxr6
sam-efxr6's Avatar
thanks for the info, don't know if i should put it i or not now
Old 02-01-2006, 04:15 PM   #10
spope
spope's Avatar
Considering I figured out all the wiring connections myself, I think my "attempt" was bloody good.
Only thing that didn't work was the air flow to the face, and that was cos I forgot to connect one of the vacuum lines. :P
It's a worthwile mod, IMO, especially at the moment - I just start the car and the a/c does it's thing - fan slows down as soon as the temp is comfortable. Big plus is in winter - your heater doesn't come on until the car has started to warm up - is much nicer than having cold air blow on you.
There is a doco on fordmods.com that can guide you through it if you are still unsure.
Old 02-01-2006, 04:29 PM   #11
InitialD
Low and Loud
InitialD's Avatar
ahh k, I thought it had power issues or something. Go the ED wiring ;)
Old 02-01-2006, 08:58 PM   #12
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
I just finished this mod on my EL XR6...took 2 days to do it right...I bought all the stuff in a "kit" from Ferntree Gully AutoSalvage...they have a forum in the site sponsors section here I think.
Basically I put in a new airbox taken from a CC car, replaced the dash loom with a high series one, added the sunload sensor and ambient temp sensor that sits up front behind the flront bumper. The wiring for that is already there, just a case of plugging it in.
Only thing is I need a high series BEM as the LCD dimming doesnt work now and all dash lights are dim, but thats an easy fix...If you are replacing the heater box you need to drain the coolant and refrigerant too.
the_scotsman is offline   Reply With Quote Multi-Quote with this Post
