02-05-2013, 08:36 AM | #1 | ||
is there a positive and negative on bulbs for a cluster for a ford au1 series can anyone help me
02-05-2013, 01:43 PM | #2 | ||
They are not marked, as incandescent bulbs are not polarity consciousness
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
02-05-2013, 03:35 PM | #3 | ||
I replaced all bulbs and stillwont light up but where the climate control is that dims with the switch but the cluster wont
02-05-2013, 05:48 PM | #4 | ||
Did you use blubs or LED's (LED's are polarity consciousness and may need to be turned around to work)
02-05-2013, 06:14 PM | #5 | ||
Auto Nerd
What can sometimes happen is that those aftermarket bulbs are half a millimeter out and the metal contacts are not touching from the circuit board to the light bulb.
You will have to take the panel out and put it on the bench. Good idea to check you have battery voltage and ground on the two metal contacts either with a multimeter or testlight. I cut two little pieces of aluminium foil and fold them into the shape of the metal contacts so that they are around 1mm in thickness. Then simply place on the back of those metal contacts on the circuit board and screw the bulb in over the top. Everything then should be locked in tight. |
