Old 15-07-2013, 07:31 PM   #1
tasauxr6vct
Default au clutch or cable stuffed?? HELP
Hey ive posted this elsewhere but not sure if in correcg area..
I was pulling out of shop before in first gear when i put clutch in to go to second i heard a loud bang and the clutch went straight to the floor.
Everything is still connected and whe i lifted the hood and pulled on cable from opposing directio it was tight but when i pulled in direction u pull it back to adjust there was like 10cm+ worth of play even with it full adjusted but whe u pull u canhear the clutch pedal banging as it gets back into position.
I drove home as back doors wont lock and wasnt in safe spot, so prob stuffed the t5 changing gears..
Also have done the firewall cable plate mod thing and reinforced pedal box. Everything looks co nected still and the cable doesnt look snapped unless the cable under the rubber covering is snapped as i didnt change when the firewall and pedal box stuffed up.
Ive got no idea if someone could shed some light would be great.
It has heavy duty clutch and on ebay ford 4l cables r 80 inc postage (if thats the prob)
tasauxr6vct is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 07:36 PM   #2
LPGUTE
LPGUTE's Avatar
Default Re: au clutch or cable stuffed?? HELP
have a look at the pedal box again carefully, i think it went.
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 09:14 PM   #3
tasauxr6vct
Pedal box is fine. Must be clutch cable but there are only 4l ford cable replacements so not sure if they cant handle my heavy duty clutch or just needs changing after a while...stlill pain in the ****
Old 16-07-2013, 12:59 AM   #4
Dezza
Parts bin special
Dezza's Avatar
They're pretty common to snap. I've done 2 of them in my EA within a few years of each other.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 08:31 PM   #5
tasauxr6vct
Cable is old and needed replacing anyway but cable didnt snap or stretch.. the bit from cable that hooks on to clip on flywheel was bent or mustve snapped a piece of metal from it. The bit under the dust cover. I tried re bending it and reinforcing with **** but clutch destroyed all my efforts the first time i pushed clutch in... whats the part called i need and is this common..
Old 16-07-2013, 11:04 PM   #6
tasauxr6vct
Does anyone know what the part is that the other end of clutch cable connects to under the dust cover box near fly wheel area?? Where clutch cable hooks on too, NOT from pedal box side...
Old 16-07-2013, 11:36 PM   #7
Gaz
Got Ghia?
Gaz's Avatar
clutch release fork?
Box out job to change that
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2013, 08:28 PM   #8
White_sr_taxi
hey man did you fix it? was it like a tubey thingy that has like a bent fork on it?
White_sr_taxi is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2013, 05:29 PM   #9
Whoosha
AU DIE HARD
Whoosha's Avatar
not this stupid bit
had my spare in the console for 3 years just waiting for that snap noise
Originally Posted by Riksta
