With da Warlords
Hi All.
Went out to the shed to wash my car yesterday and it wouldn't start. The battery was preety flat, so I connected my jumper pack and kicked it over. Too start with it would wind over and then just click from the solenoid like it does when flat. So I charged the battery and the jumper pack and tried again. The second time, the car wouldn't even crank or click. So I cleaned the terminals and swapped the battery. Now with a fresh battery & jumpstarter it refuses to even wind over... No clicking even. Voltage and everything is fine? I'm wondering if the starter motor is gone? Or maybe solenoid? The smartshield light isnt flashing when I attempt to start so I don't think its immobilised. Any ideas? Maybe a good whack to the starter lol
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
inhibitor switch if it's an auto try jiggling the tbar sometimes it is just a bit of of adjustment rather than faulty
[SIGPIC][/SIGPIC]
With da Warlords
Unfortunately its a manual, so that rules it out... But its exactly the same symptom
With da Warlords
So after ringing infernosr and doing a little troubleshooting it might be the immobiliser after all.
When I turn the ignition to ON, The smartshield light stays lit up... Usually its meant to illuminate for a few seconds then turn off... So perhaps there's the problem?
not here much anymore
is the interior light blown?
2024 F150 XLT
With da Warlords
Yep tilt tray up too ford... Smartshield was active. Recoded key to BEM, and away it goes.
