Old 21-08-2013, 10:32 AM   #1
Reaper8
Reaper8's Avatar
Default Au steering rack
Hi all. I have to replace my steering rack in my XR8. It got a ton of play and starting to stick in places and is getting worse. Can I use one off a 6cyl or are they different. Thanks in advance.
Ps the ball joints and control arm bushes have been replaced so it has to be the rack.
Reaper8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2013, 11:03 AM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Au steering rack
could it just be the rack ends? you can pick up a set with boots and tei rod ends for $50 on eBay. to answer your question, yes a 6 cylinder one is the same
[SIGPIC][/SIGPIC]
Rides:
Old 21-08-2013, 11:13 AM   #3
Reaper8
Reaper8's Avatar
have a set of boots and rack ends in the shed (it is leaking into the boots). It seems more than that but, it has a sticky spot just off centre and when you turn it it like jolts a little. I don't really trust the car in corners and it is a shame as it is a fun car to drive in twisty stuff. Found a v8 one on ebay for 200 exchange so might just get that.
Old 21-08-2013, 11:20 AM   #4
FGII-XR6
FGII-XR6's Avatar
ok sounds more like a terminal rack problem I. you look around there are plenty of well priced recos on EBay some don't even need an exchange . I personally would rather spend a few extra $ on a reco than on a used one that is an unknown quantity.
[SIGPIC][/SIGPIC]
Rides:
Old 22-08-2013, 01:33 PM   #5
mik
mik's Avatar
i did a bit of a rebuild on my xr6 rack some years ago, if you want to have a squiz at the parts, i did it from top to bottom, it was fairly fiddly and i spent a bit of time innovating tools to do the job, after looking back on it for the effort involved to me a c/o looks to be well worth it.
http://www.fordforums.com.au/showthr...g+rack+rebuild
Old 27-08-2013, 05:52 PM   #6
BRADFORD000
Yes you can use a 6cyl rack, but need something to fill the hole where the power steering pressure switch goes as v8's dont have the hole.
If you want more inches ,stroke it!!
BRADFORD000 is offline   Reply With Quote Multi-Quote with this Post
