Old 19-01-2006, 12:04 AM   #1
steelo
Default EA Air con Problem
The turquise (green to me) vacuum hose that runs from the heater tap to ? doesnt appear to be working. I can suck and blow on the end that goes to heater valve and have airflow. I have the glovebox out but cant see where that damn vacuum line goes.
Also does anyone have a fix for the broken lever on the passenger side airbox that attaches to a vacuum thingy to open and shut the vent?
steelo is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 05:27 PM   #2
AshMan
Girrrrr!!!
AshMan's Avatar
Mate that vaccuum line will go to the panel where your hot/cold and vent controls are, if I remember correctly.
What is it that is broken? I might be able to help you with a very cheap replacement.
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 05:29 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
that line only affects HEATER not aircon.
what is your aircon problem.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 08:17 PM   #4
steelo
Default Green vacuum hose - heater
I can suck and blow on the hose whenit is disconnected from the unit on the heater hose.
I dont have any heat coming out of vents when climate control is on max and the compressor seems to be always engaged
I have replace the unit on heater hose with a new plastic type.
Old 19-01-2006, 10:02 PM   #5
rebornafordman
Ive had similar issues with my faimont ghia. I had the heater tap replaced it was stuffed. If the butterfly that shuts the hot water off has a hole in it it will let hot water through all the time, this may warm up your air con. But by the sounds of it your having heater troubles.
Do a diagnostic on the climate control and see if you get any errors. You should be able to find instructions on how to do this in the forums. Its been awhile since i did mine and ive forgotten.
Did this on my own car cause the heaters wouldnt work and got an E2, which i believe is blend door failure . I havent tried the heaters since the tap was replaced- its too bloody hot!
Other than that check all your vaccum lines i guess.
Hope this helps.
rebornafordman is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 11:17 PM   #6
frost
frost's Avatar
That was my problem, then my pump packed it up now i cant get air out of the head vents now i took the dash out to replace the heater core
frost is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2006, 08:15 AM   #7
EA2BA
PM me if you want
EA2BA's Avatar
E2 = blend door motor (or blend door itself) , either way it's a whole dash out job to fix the problem.
Old 20-01-2006, 09:23 AM   #8
steelo
Default Diagnostics for Climate Control EA Fairmont Ghia
Can someone direct me to these I've searched but cant find the instructions.
Thanks
Old 20-01-2006, 09:34 AM   #9
EA2BA
PM me if you want
EA2BA's Avatar
igntion on, press the floor and off button at the same time, tell me what error codes you get, if any.
Old 20-01-2006, 09:38 AM   #10
EA2BA
PM me if you want
EA2BA's Avatar
ERROR CODE DESCRIPTION
E1 Electronic Control Unit
E2 Blend Door Servo Motor
E3 Cabin Sensor
E4 Solar Sensor
E5 Ambient Sensor
E6 Evaporator Temperature Sensor
E7 Engine Temperature sensor
Old 20-01-2006, 09:16 PM   #11
steelo
Default Reads E2
So I guess its a dash out job.
Is that why the green or turquiose vacuum hose from hot water valve can be sucked and blown and no resistance?
