13-12-2005, 11:46 PM | #1 | ||
i am thinking of replaceing the old 3.9 with a 4l from an ed,this is a staight swap is it not,how much roughly for a 2nd hand one would you think is reasonable fitted.
is there another engine i could swap it for. i don't want to swap manifolds or ecu's either. anyone got a 4 litre engine for sale and can they fit it if i provide the amber fluid and some meat for a bbq ?? i am serious,,
2000 AU Wagon |
14-12-2005, 12:56 AM | #2 | ||
Thumbs up for fossil fuel
Are you running a 3.9L CFI, or MPFI engine at the moment?
Where exactly in Aus are you? Is your car currently driveable? Mike
God created F-trucks so that you could put their engines into E series. 1992 EB Fairmont 351cu in Windsor Roller Cam Valve Body "Shift Kitted" BTR 4spd Auto Hi Tek Headers Tri Y Twin 2.25 into Single 2.5in 17in x 8in BA XR8 Copies 235x45x17 Nankang NSII Ultra Low King springs Whiteline 30mm Swaybar Nolathane box section trailing arms Slotted DBA front rotors Yella Terra roller rockers |
14-12-2005, 03:18 AM | #3 | |||
FPV GT
if you look around you should fined one for about $950 fitted. :hihi: |
14-12-2005, 07:53 AM | #4 | ||
it an mpfi and i'm in northern nsw.
i want to get an e series motor as its to much stuffing around to fit the au one
2000 AU Wagon |
14-12-2005, 10:15 AM | #5 | |||
I am on the gold coast and have an EB motor you could have for $250 It needs a new ign module, rocker cover gasket and waterpump. You should have all the sensors for it already. 165,000km on the clock, pulled it to replace it with a V8. Very good compression. I cant remember it leaking too much oil (its been about 10months since I used it last). People will prob think i'm stupid for saying this when i'm trying to sell a motor. E series engines are prone to headgasket failure. On frequent stop-start driving and engine on/off frequently opperation..... high 100,000's kms the gasket will start to die (or even earlier). On long haul cars you are looking at (approx) low to high 200,000's km. Many engines do not follow this rule, its just a general guide. I could place no guarintee on my engine. It worked well for me, thats all I can say. I couldnt do the install as I am flat out doing my own car. Mike
14-12-2005, 10:21 AM | #6 | ||
Turbo Dinosaur FTMFW
buy mikes engine, and fit an AU head gasket before the motor is dropped in ;)
14-12-2005, 11:08 AM | #7 | ||
so what would involve changing from an EA - AU? can u still run ea injectors, and other syuff like that.
luke |
14-12-2005, 11:15 AM | #8 | |||
PM me if you want
Get an EF/EL motor will fit straight in no drama, and need just the timing case changed and the balancer if you dont want to run serpentine. (AFIK)
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
14-12-2005, 11:39 AM | #9 | ||
y do you need to change the balancer and timing case?
and can you run the EA ECU with an EF-L motor? luke |
14-12-2005, 12:42 PM | #10 | ||
Shoot.
Jason, if you drop in an EF/EL donk with serpentine, are there any major changes/mods you need to do for it to all fit and work correctly?
20V Turbo |
14-12-2005, 02:26 PM | #11 | ||
Custom User Title
Hmmm I am thikning about throwing an AU engine in my EA, as it would turn out to be the same cost as getting the headgasket done (it hasn't gone yet, but it slowly leaking) and the getting the electrics sorted...
Can you use the EA radiator, if you want to use AU thermos? Can you use the BBM? How much do AU engines go for...complete with all anchilaries, and where is a good place to look for them? I got quoted $1600 for a long motor, here (Canberra)...so where do you find these uber cheap $950 AU engines :| How much not installed, ie) how much of the $950 is labour? |
14-12-2005, 02:46 PM | #12 | ||
I paid $900 for mine. Complete with BBM injectors etc, but not PS Pump or Alternator etc. Since then there are engines around here for about $850 with about 30k on them.
The AU manifold isnt suitable for using on an e-series though because of the different MAP sensor. You'd need an EF/L manifold. If you want to run Serpentine with the EA/D manifold you'll need an XH1 Ute Belt Tensioner.. rare as and very expensive from ford. EA/D style belts are a pain to fit to the AU motor because there is a mounting lug missing for the alternator bracket and some of the lugs for the aircon compressor are too long, as well as the timing cover and sump needing the attention of a grinder. AU thermos are more difficult to fit since they are different size and mounting is different design to the EF/L Thermos which can be fitted to EA Radiators as long as the tanks have got the mounting bolt holes in them at the top. |
14-12-2005, 03:09 PM | #13 | ||
Shoot.
What are XH1 belt tensioners worth new?
20V Turbo |
14-12-2005, 03:14 PM | #14 | ||
$300+ Iirc
14-12-2005, 06:17 PM | #15 | ||
when i fitted my AU engine i had to fit an EF radiator, as the outlet on the water pump is a different size to the EB one. not sure if you can swap water pumps.
14-12-2005, 06:21 PM | #16 | ||
Water pumps are all interchangable.. Have to match the pump to the belt setup though.
14-12-2005, 09:31 PM | #17 | |||
If you have an ea with MPI then i would put in an AU long motor, and keep the serpentine setup. If you grind the bottom of the sump then you will have heaps of clearance. if you use an EA-ED radiator, you will need to get a piece of pipe made that can reduce from the larger EA hose to the AU hose. Maybe a new EF-EL radiator could be a good idea if your current radiator is old... Its definitely worth doing!!! There is a wreckers in brissie that has a couple of low k AU motors for around $650, but no accessories, but includes the manifold... So you could sell that. You will need to get A/C, P/S ( or change pulleys) and Alternator... GO THE AU!!!
Powered by Rollin Motorsport Turbo Barra ED 4L
14-12-2005, 09:34 PM | #18 | ||
V8 Ute V8 Boat
yer i would spend a little more money and get the ED XR6 Motor it will go real Nice
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
08-01-2006, 08:11 PM | #19 | ||
is this still available?
2000 AU Wagon |
09-01-2006, 01:49 AM | #20 | |||
As said before, I am on the gold coast. I have an engine crane, so you all you need is a trailer or ute. The engine needs a new ignition module, rocker cover gasket, these parts are readily available. The water pump and fan are seperate from the engine, but included in the price, both appear to be in good condition. Oh yeah, the engine needs an oil change, he he he. You should have all the sensors for it on your current motor. And again I could place no guarintee on my engine. It worked well for me, thats all I can say. You are quite welcome to inspect it as closely as you like (without pulling it apart obviously). You can see all the rocker gear, as I have already removed and replaced it to check it myself. Let me know. Mike
09-01-2006, 11:00 AM | #21 | ||
well i'll just have the distributor taken from the 3.9 and put on the ed donk,,defenately interested,,just may not have the money to soon though,,daughter is going into hospital soon. i'll keep you posted as to whats happening,,try to keep for me..
2000 AU Wagon |
09-01-2006, 11:17 AM | #22 | ||
anybody home on the 20th of this month??thats when i'll be up that way with the trailor,the money will be in my account in a few days it's just were going away for a week,,and i'll take what ever comes with it,,pm me your address and phone number,,i'll be getting the sump gasket replaced before it's put in anyway to be on the safe side..
naughty
2000 AU Wagon |
09-01-2006, 02:14 PM | #23 | ||
i just found out that it will cost me just as much to change the 3.9 over to the 4l as would to just fix the 3.9..so 4l here i come....the mrs said go for it..
2000 AU Wagon |
10-01-2006, 02:30 AM | #24 | ||
Sorry, I have been up at the sunshine coast all day!!!!! I would have reply'd earlier, rather than now at 1:22am.
I have sent you a PM with a short message and my details. I will be keeping the motor for you. Looking forward to seeing you soon. Mike
10-01-2006, 09:38 AM | #25 | ||
thankyou muchly,,look forward to meeting you.
2000 AU Wagon |
20-01-2006, 12:02 PM | #26 | ||
Best of luck with the motor, I hope you get some good service out of it.
Nice doing business with you. Mike
20-01-2006, 09:54 PM | #27 | ||
so naughty picked it up..kewl
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds: |
20-01-2006, 09:58 PM | #28 | ||
yep,this morning,looks to be in good nick to,just needs a bit of a clean up,
thanks mike,,did you get your problem sorted???
2000 AU Wagon |
