Old 17-01-2006, 04:05 PM   #1
niko
likes falcon's
niko's Avatar
Default db tested my exhaust
on idle was=76db
3500rpm and let go of throttle peaked= 100db
giving it even more peaked 104-106db
tested a mates proton gti, idle was 92db
3500rpm peaked 110db...lol
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 04:07 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
3,000rpm must be less then 94db according to the EPA afik.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 05:25 PM   #3
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
You are deeply moved by the sound of your vehicle blowing raspberries out the exhaust
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 05:36 PM   #4
gozza
gozza's Avatar
i got 114
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 06:26 PM   #5
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Where were you holding the mic?
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 06:36 PM   #6
niko
likes falcon's
niko's Avatar
really close and all different positions
Old 17-01-2006, 06:36 PM   #7
mcflux
mcflux's Avatar
Isn't the mic meant to be 1m from the exhaust, and not directly behind it? (like some shallow angle away from the actual exhaust)
Not saying you haven't done this... so it's actually more of a question that me is asking you (or others in the know)
Old 17-01-2006, 06:38 PM   #8
niko
likes falcon's
niko's Avatar
those readings were prolly 30cm away from the exhaust
i tried my stereo out also, where i sit it pumped between 85-100db with sub and without, sub pumped 110 directly infront of it
Old 17-01-2006, 06:46 PM   #9
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
dB meters expensive?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 06:49 PM   #10
Gunns
Gunns's Avatar
has to be less than 90db @ 3150 rpm
I know cause I had to get tested. Dam EPA!!!!!!!!!!!!!!
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 10:45 PM   #11
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
What illegal db? gthofan was done by the epa bout a week ago!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 12:10 PM   #12
gozza
gozza's Avatar
mine was held no less than 30cm no more than a meter away
Old 18-01-2006, 01:31 PM   #13
BABOSS
BABOSS's Avatar
The limit is 90db for an I6, i know this because i got done and was only 1db (91db) above the limit so they chucked in a resi and took it down to 89db (it may vary in different states) The limit for V8's is higher than 90db not sure of the exact figure.
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 01:47 PM   #14
LTDHO
The one and only
LTDHO's Avatar
Niko - the EPA are now your friends......
Well they will expect you to pay them when they visit next!
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2006, 11:03 PM   #15
soulfire
Kermit the Frog
It needs to be less than 90dB for a vehicle newer than 86 as far as i know.
1 metre away at 45 degrees I thought?
soulfire is offline   Reply With Quote Multi-Quote with this Post
