Old 24-01-2006, 11:29 PM   #1
str02
99 AU Futura
str02's Avatar
Default Coolant temp sensor? location
I have had a look at the wiring diagrams here but cannot locate the temp sensor that would activate the cooling fans on the radiator. My fan/s will be on after 3 minute drive down to the shops, so I am assuming that there is a temp sensor and that the sensor may be faulty. Air con is off, no traffic etc so no reason for the fan/s to be cooling. So my plan is to locate the sensor and disconnect it before a short drive and see if that kills the fan
Thanks in advance
str02 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 08:20 AM   #2
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
There was a post kinda like this a few days ago - how long between dirves is your fans coming on after 3 mins; how hot is it outside; how hilly is it; what is your temp gauge showing?
Alot of ppl worry that their fans are coming on for no reason and worry about it, trust me, you only need to worry if they don't come on.
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 05:43 PM   #3
The Dok
The Dok's Avatar
While your at it, it may pay to replace the thermostat as they are a common cause of this problem if they are stuck shut or not opening fully. Do a forum search beforehand as there was a thread on this very problem (thermostats) recently because some brands are not suitable for the AU. _2:
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 06:42 PM   #4
str02
99 AU Futura
str02's Avatar
Stone cold before I drive it, not high ambient and temp gauge shows "normal"
Old 25-01-2006, 09:26 PM   #5
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Then don't worry about it! Car's not overheating! :
