28-07-2014, 03:33 PM | #1 | ||
So I have sold my AU XR8 SII ute. I will be sad when I see it leave my driveway on Wednesday. The parts that I pulled off were the MSD coil packs and leads, whiteline F&R swaybars, 4 piston front brembos and slotted rotors, staggered 19's, black momo gear knob and genuine ford hard lid. This is how she looks atm awaiting pick up.
So I plan on replacing it with a P250 and I am hunting one in stock form. I have my eye on one atm but I will wait probably till October to actively locate a possible purchase.
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
29-07-2014, 07:58 PM | #2 | ||
Next upgraded Mk1 Leopard
Good luck with your next ride, hope its as good as your old
UK
30-07-2014, 11:00 AM | #3 | ||
in regards to my next car, i am thinking that at some stage i am keen to replace the heads (with aftermarket - i read a lot of people recommending AFR 185's) and port match the intake. Am i better off holding off from buying a set of new headers till then, or can i buy a set before that stage that will work well with both the gt40p's and (scenarios based) afr 185's??
31-07-2014, 08:16 AM | #4 | ||
5.6L x 2 pilot
Congrats on the sale Shaun.
I am using the same Hurricane headers on my AFR 165s that I was using on the GT40Ps. I guess it will come down to the exhaust port size on the 185s. You should be able to look that up. Using the Summitracing site, I did a compare of the AFRs 1472 (the 165s I am running), the 1422 and 1492 (the two 185 variants) and all three have the same 68cc exhaust runner volume. This would be a fair indication that they would all be the same size? Obviously more research would be required to confirm. Good luck with your search for nice P250. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
