Old 15-07-2014, 07:25 PM   #1
SLO247
Default Double DIN in AU-Mounting methods
So, the time has come to replace the premium sound head unit in my Ghia. I can no longer play cds and its driving me nuts.
I'd like to fit a Double DIN DVD deck, my main concern is mounting it.
I know a few blokes here are running them in AUs, how are you mounting them?
SLO247 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2014, 04:25 PM   #2
Vincenzo
Vincenzo's Avatar
Default Re: Double DIN in AU-Mounting methods
I'm surprised nobody has answered by now. The problem with mounting a non standard Double din in the AU is if it is flush at the top it sticks out about 2cm at the bottom. If it is flush at the bottom then it is recessed in at the top about 2cm.
If that does not worry you then go for it. If the Aesthetics look out of place then go a single din unit and maybe look at a flip out head. With the right accessories you can still use your steering wheel buttons just make sure the head unit has the appropriate hole in it.
Cheers Vincenzo
$DO || ! $DO : try
try: command not found - (YODA the Geek)
"WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion
Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum
[SIGPIC][/SIGPIC]
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2014, 05:21 PM   #3
SLO247
Thanks for taking the time to reply.
I did run a double DIN unit in my old AU previously. I think I used some of the strapping they use for centrallock actuators in those universal kits.
I was hoping to see how others had mounted theirs.
I also considered a flip out unit but worried about it clearing the bulky AU dash facia and the stereo facia itself.
The steering wheel controls seem to require a fairly pricey adapter to work. It seems generally its only some Jap cars that work natively.
At this stage I'll likely fit a single DIN unit and the Aerpro full facia to fill the gap and mount it. They work quite nicely. I've also been offered one I don't mind for an inexpensive price.
I hoped to see how others had mounted up theirs!
Old 17-07-2014, 05:23 PM   #4
FTE-063
FTE-063's Avatar
i was going to, but i didn't as SLO247 asked me about it in my build thread and i told to look back on post #174
FTE-063 is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 12:34 AM   #5
SLO247
I saw that. Its either held in with foam or that surround you made? Did that clip in? Sorry, I was looking for more detail. I do appreciate your reply.
I bought a single DIN unit tonight as I found one I liked.
Old 18-07-2014, 07:52 AM   #6
FTE-063
FTE-063's Avatar
like i said it is just held in there by the TRIM that i made
Old 18-07-2014, 09:53 AM   #7
SLO247
Thanks.....
Old 18-07-2014, 11:29 AM   #8
thehitcher
I mounted mine by wedging it with timber and cork... But Plan on making a bracket that uses the screws behind the ash tray and some 1mm zink anneal...
thehitcher is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 02:21 PM   #9
Dauphin
Irregular member
Dauphin's Avatar
I remember I had two units in mine at one stage and thought I had mounted and kind of jammed them nice and securely. Then one day someone turned in front of me, forcing me to brake hard. The sudden stop led to them flying out and onto the centre console against the T-bar!
Old 21-07-2014, 12:55 AM   #10
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Mine was fitted by the retailer and they used one of the 'strapping' thingos at the top on each side bent into a right angle and screwed into the factory mounting point. There's nothing holding it in other than that (I think it sits on a part of the dash frame?) and it's been fine for years though the trim drops off occasionally :-s
Mine sticks out a little at the bottom and is recessed a little at the top...
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 01:06 AM   #11
raised by monkeys
raised by monkeys's Avatar
someone was looking at using a dead factory unit to make a fibreglass mould to create a factory look mounting face with a recess. Sounds like a good idea but a lot of trouble. I think a single din is the best option. Got a space for gauges then too.
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 01:07 AM   #12
Silver'
Silver''s Avatar
found a pic - this is with the trim off which you could argue looks better tan with it on.
TE2 #116
Old 21-07-2014, 11:31 AM   #13
SLO247
Nice to hear how some others have done it.
Old 26-07-2014, 10:51 AM   #14
Jay.Blanket
Jay.Blanket's Avatar
used the trim that was around it originally and grinded it down at the top to make it fit... then build it up on the sides and underneath with some expandafoam and shaved it down to suit then carbon wrapped it... then i decided i didnt like the carbon wrap and have since remodeled it completely and going to refit it today.. might put up another pic this arvo if i remember
White TSHavoc
Go check it out at AUFALCON
http://aufalcon.com.au/jay.blanket
Jay.Blanket is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2014, 10:52 AM   #15
Jay.Blanket
oo forgot to say. pretty much held there by a really good friction join.... haha seems to work.. might make some rubber wedges or something though to make it abit tighter though
White TSHavoc
Old 26-07-2014, 11:48 AM   #16
raised by monkeys
Single din for AU. That is all.
cheers
Shaun
Current
Previous
Old 27-07-2014, 12:06 PM   #17
towtaltowing
when i had a double din in my au i use these window packers taped to the sides of the unit so it was Friction fitted
https://www.google.com.au/search?q=w...w=1263&bih=654
towtaltowing is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2014, 10:05 PM   #18
ronwest
All Bran = Regular Member
Can't rem how he mounted it but Umineko had the best surround I've ever seen
Old 30-07-2014, 10:35 PM   #19
Silver'
Silver''s Avatar
The place where I bought mine offered to do a show car style fascia like that for $300 but couldn't give me a firm price so I said no. Liking at that I wish if said yes, that's a big improvement!
TE2 #116
Old 30-07-2014, 10:35 PM   #20
Jay.Blanket
lol yeah that one looks amazing.. far better than mind.. lol.. note to self.. get good as maybe fibreglassing... :S
White TSHavoc
Old 30-07-2014, 10:44 PM   #21
Silver'
Silver''s Avatar
Maybe this will be worth the wait?
http://www.fordforums.com.au/showthread.php?t=11414819
TE2 #116
Old 31-07-2014, 08:46 AM   #22
FTE-063
FTE-063's Avatar
well here is mine i use the factory fascia by trimming it and adding balsa wood to make it thicker, it's not as good as the one in the LTD but i like it
Old 31-07-2014, 10:22 AM   #23
GasoLane
Former BTIKD
GasoLane's Avatar
We had the single/double din dilemma with our old Fairlane and eventually went with a single din Clarion with an adjustable screen.
Old 31-07-2014, 01:34 PM   #24
SLO247
SO they do clear the dash. I wondered about that. Thanks.
