21-10-2014, 08:04 PM | #1 | ||
Au Falcon = Mr Reliable
Hi all, how are we! My AU has just started to develop a tonk, tonk, tonk sound right rear, going right around roundabouts. Also noticed the last rear exhaust hanger rubber holder has got a split in it, just wondering if related. Have you ever heard that sound in a AU before. Thanks for any input!
cheers, Maka
22-10-2014, 08:54 AM | #2 | ||
Just tested it while out for a drive & its not the exhaust. That leaves a couple of other things to check now. Very interesting!
cheers, Maka
22-10-2014, 06:25 PM | #3 | ||
Diff or handbrake i think, needs closer inspection. Inspected the shocks they are good, springs probably a bit old now though. I should find the issue soon.
cheers, Maka
22-10-2014, 06:40 PM | #4 | ||
Hey mate I think I have the same issue, got my diff replaced and handbrake adjusted...suffice to say the handbrake is useless again! Typical falcon! But I have that noise, I only heard it when braking under 30km/h but it has become more prominent now, I'd suspect handbrake first as my diff is brand new besides the housing and yoke!
Let us know how you go I haven't had a chance to get it sorted it.
Ride 2007 Ripcurl BF Xr6 Ute Mods to Date Ceramic Coated Pacemaker 4495s 2.5" Dual Venom exhaust, Bluepower CAI Eaton True Trac with 3.9s 20% Underdrive EcoLpi Motor RWKW: 200.0 Nm: 394 Mods to Follow Supercharger |
23-10-2014, 07:56 AM | #5 | ||
Hi Tutor, thanks for the reply! Yeah no worries, i'll let you know. Empty boot atm
cheers, Maka
23-10-2014, 08:40 AM | #6 | ||
Ha ha, no noise this morning doh, so its intermittent. Yesterday i dismantled some stuff to have a look see & i securely fitted the rrh shock body plastic protective sheath which was pretty loose fitting & the handbrake cable is zipped tied near were the cable goes into the brake hub but rubbing against the diff housing, so its floating & moving a bit.
The sound is bit hollow sounding though so its a little clue i think, i'll keep ya posted! cheers, Maka
24-10-2014, 09:29 AM | #7 | ||
Its fixed for now i reckon, spare is tightened down properly, boot emptied of not needed tools & stuff, rrh shock is fine now, exhaust hanger rubber holder fine now, handbrake cable routing all good now.
The noise was serious at first & getting worse but all good now. cheers, Maka
