Old 28-10-2014, 05:19 PM   #1
Spurious
Default Where to find VIN decoder for AU2?
FF AU technical data links (in the AU to BF category) only have the AU VIN decoder. So where to get the AU2 info?
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2014, 05:46 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Where to find VIN decoder for AU2?
I would have thought that the VIN for the AUII would hold the same data as for the first AU.
But anyway have a look here.....
http://www.fomoco.com.au/ID.html
Old 28-10-2014, 08:45 PM   #3
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Click the vehicle tab and enter your 16 digit vehicle tab - should start with 6FPAAA**********.
Should give a rough idea how it left the factory.
http://www.etis.ford.com/vehicleRegSelector.do
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2014, 08:45 PM   #4
Spurious
You are correct!
It's the option codes in particular that I'm curious about.
My AU2 is plated (drivers shocky tower) with the Tickford enhancement badge, but when looking on the FordEtis web site it doesn't show the sports suspension as a factory fitted option.
I did get a ford build certificate however which DOES state this option.
Just a discrepancy with the electronic data logging system I guess.
Confusion setting in....too many codes....too many codes & too many fords make flivverford go crazy!!!
The link you put up GasoLane only features early falcons, up to the XB's basically.
Old 28-10-2014, 08:49 PM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
Ah ok, but it does give the production dates (month) for yours if that would be any help.
