Any one knows about 2006 LS LX 2.0 AUTO Ford Focus Fuel Filter location?
If can provide pictures will be appreciate. |
#2 | |||
Nice kitty . .
Apparently its a royal pain to change. This might help . . . http://myfordfocus.com/how-to/fuelfilter.htm And this . . . http://forums.focaljet.com/team-tech...placement.html ![]() Fredo
Just remember, amateurs built the Ark and professionals built the Titanic! Late 2005 LS CL, 5spd Manual, 5 Door, Titanium Grey To Do List:- :- Using 95 RON Fuel (DONE -easiest upgrade of all) :- XR5 Springs (DONE) :- Lower air box removal (DONE) :- K & N Panel Air Filter (DONE) :- 2.25" Cat Back (DONE) :- DBA Brake upgrade (DONE) |
Quad Cam
Both those links refer to the LR Focus, I don't think the LS, LT or LV have a fuel filter.
I just recently bought the Haynes 2005 to 2009 Focus repair manual and it has no mention of a Fuel Filter. To be honest I'm pretty surprised about that but after checking out the underside of the car I cant see one anywhere. There is a big charcoal canister at the rear of the fuel tank but that is all I could see. My Focus is a 08 LT by the way. |
Hi Fredo, I did reasech on google. I got that two urls as well. and it looks like 2006 model is different with 2005 model.
#5 | |||
That is really painful. Even Haynes does not show about location of FUEL Filter. WTF. |
I already spent moren than one hour do looking for the Fuel Filter under my car. It does not show up. I hope south africa does not rip off it.
Quad Cam
My guess is that it probably has a permanent fuel filter in the fuel tank.
If permanent seat in tank, that no way i can do, but i already brought one fuel filter. what a shame.
Nice kitty . .
Yeah yeah you're right guys - my error.
Must be in the tank??? Un-good . . . Fredo
#10 | |||
![]() Anyone has experiense change this in fuel tank 's fuel filter? |
Went to change my filter ...
Its a Dec 05 model ... No filter anywhere ...just lines running to the tank... Is the late 05 model the cutoff for no external filter ,,,? |
#12 | ||
Where to next??
In tank fuel filters.... how very convenient!
#14 | ||
rotters ,,!!
superchumps still sold me one for a car that does not actually have one ... ohh well ,,, looks like the daughters car ,," lr focus " gets a free fuel filter next service .... thanks for the replies fellas . |
#15 | ||
Put one in.
Get an aftermarket filter (easier to change) some 2x Proflow AF109-05BLK hardline adapters. Cut fuel line use the hard line adapters measured to fit filter. Perfect. |
#16 | ||
would that ,," adding a second filter ,, stock style sort for the earlier sort " , disturb the fuel system tho ,? .
#17 | ||
Would have to look into it a little more and ask questions.
I used the above method to replace OEM filter. FG I should add. They are a bastard to undo and going to run e85. So cut fuel lines and removed replaced with Aftermarket one. |
#18 | ||
Some more info in here.
http://www.fordxr6turbo.com/forum/in...Ewhat-I-Did%21 Hardline fitting. http://m.ebay.com.au/itm/14092307931...84.m1423.l2649 |
#19 | ||
cheers mate ,,,
realy rooing the fuel pump i ordered of fleebay ,, only to be told two days later ,,, " hey mate ,, the one we have listed , is not the right one apparently ,,, have removed the listing till rectified . paypal payment being refunded . " .. the blasted thing had the filter on it no doubt .. |
#20 | ||
Pic's of install.
#21 | ||
nice lookn bit of kit n all .
