Old 10-02-2006, 08:41 PM   #1
slamd ef wagon
Default vernier gears
got my cam fitted today im still running it in i havnt taken it over 3grand yet but i really cant feel any differance i got the crow 2222519 and a vernier gear, with the gear cam can u adjust it to give more power?
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS
slamd ef wagon is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 08:47 PM   #2
AshMan
Girrrrr!!!
AshMan's Avatar
should give you more leeway adjusting the timing, if you advance the timing alot you will need to run premium or premium with octane booster otherwise you'll get pinging (detonation).
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 09:04 PM   #3
AshMan
Girrrrr!!!
AshMan's Avatar
this is from crane cams website:
"How does Advancing or Retarding the camshaft's position in the engine affect performance?
Advancing the cam will shift the basic RPM range downward. Four degrees of advance (from the original position) will cause the power range to start approximately 200 RPM sooner. Retarding it this same amount will move the power upward approximately 200 RPM. This can be helpful for tuning the power range to match your situation. If the correct cam has been selected for a particular application, installing it in the normal "straight up" position (per the opening and closing events at .050" lifter rise on the spec card) is the best starting point. "
Old 10-02-2006, 09:13 PM   #4
AshMan
Girrrrr!!!
AshMan's Avatar
You have an auto gearbox??? it says "stage 2 shift kit" in your sig...
I think the first thing they say to do when you get cams done (apart from the valve springs) is to get a high stallie or manual...
Dunno mate...
Old 11-02-2006, 12:35 AM   #5
slamd ef wagon
ok thanks guys, so it sounds like by wat u have said the power cant really bot uped or downed by adjusting it i just thort id get a bit more power out of my new cam than wat i did id say getting my exhaust done gave me more power up than now geting the cam but i gues the exhaust cost more
yer manual is goming in 3 weeks or so
Old 11-02-2006, 09:02 AM   #6
Stav
Smile
Stav's Avatar
The manual or high stall and a bit of patience for the run in should start to see how good the cam is.
Old 11-02-2006, 10:35 AM   #7
falconkid
On here daily
i found that cam to give most of its performance jump was after 3 grand. it breaths alot better after that.
JIM
falconkid is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 11:55 AM   #8
slamd ef wagon
cheers guys, yes i have noticed the longer its been in there it has given more power since i first picked it up from the garage
cheers for the help
Old 11-02-2006, 05:48 PM   #9
UNR8D
FORMER T3 OWNER
UNR8D's Avatar
mate you need to give it alot more ИИИИ than 3grand lol my cam wont come in till 3200RPM shows on my dyno chart, shift kits are good but team it with 3.9 diff gears and you will notice a HUGE difference.
Mischief.TV
you can sleep in your car, but you cant drift your house...
UNR8D is offline   Reply With Quote Multi-Quote with this Post
