Old 28-04-2015, 06:37 PM   #1
Tonz
Default A jack for my ute
my problem is the box I have on the ute is great in most areas except when needing to change a flat tyre. because of the low clearance between top of tyre and wheel arch I had to use 2 barrel type jacks.
1 to lift the axle off the ground
2nd sitting on a block to lift the chassis up enough.
I need to lift the chassis 380mm minimum off ground for wheel to slide off
Ideally I'd like a trolley jack but max height for something I can carry and store is 330mm.
What other suggestions can you come up with...
Sissor Jack ... what height?
Old 28-04-2015, 09:46 PM   #2
Grum
Bringing the Spartan back
Grum's Avatar
Default Re: A jack for my ute
http://www.supercheapauto.com.au/onl...ecommendations
or a similar product of another brand
East Coast Suspensions
Road - Race - Performance & Prestige Car Service
BOSS 5.4L Silicon hose kits for sale
BA/BF FPV parts for sale
The only negative thing in your life should be camber
Blue Power Racing Enhanced
Chris & Craig - Thanks!
Grum is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2015, 10:46 PM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
http://www.transquip.com.au/products...K-1850-KG.html
I don't think something this small raises up enough though :(
Old 28-04-2015, 11:02 PM   #4
mik
mik's Avatar
perhaps you could put some adjustable air shocks on the ute , then you might
only need the one squat jack under the axle?
Old 28-04-2015, 11:16 PM   #5
Tonz
Not wanting to be pedantic fussy, but... bottle jacks are what I have used but called them barrel .
Air bag... hmm 4WD specalist didnt recomend them for tyre changing.
Air shocks hell the cost but it may head down that way, if.... we want to keep it long enough to pay them off.
Thanks guys I appreciate your help so far.
