Old 07-02-2006, 08:00 PM   #1
335JET
@jas_23_
335JET's Avatar
Default caster/camber kit
i am soon to lower the EL on King spring superlows, will i need a caster/camber kit.
are they important or can i do without it, and roughly how much do they cost.
335JET is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 08:50 PM   #2
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
AFAIK u will need it.
for wheel alignment?
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 09:03 PM   #3
Tiga_EL
Tiga_EL's Avatar
Yes you will need it. Last service went in to find the inners of my tyres worn to the brink. while i had an allignment etc done. The pro there said its a necessity... I dont have one as of yet, but will soon be getting one.
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 11:32 PM   #4
oneredED
need more boost
oneredED's Avatar
Superlows? For sure, you'll need a camber kit. I have the shim type camber kit (same as your current camber adjustment, but with longer threads to fit more shims) because it was cheaper, but i have since heard from a couple of people that the ratchet-type ones are un-reliable... I'm happy, the shims work fine...
If you dont have it and adjusted correctly, you'll wear the inside of your tyres extremely fast and they'll be useless even though you can see heaps of tread on the outside...
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 02:04 AM   #5
XRated
Shoot.
XRated's Avatar
^^ What they said. Ratchet types aren't recommended because they can move. Shims can just be whacked in there and you can forget about them (pending the car stays at the same height).
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 10:02 AM   #6
gozza
gozza's Avatar
mine were 180...dunno wat brand.......kmac make adjustable ones which are probly more expensive
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 01:42 PM   #7
efbeggza
03 BA Fairmont Ghia
BOSS4LTR, let me know how you go with your lowering setup. I'm in the market to get it done..Realising that I now need the camber, I'm thinking the price will be around 1-1200 to get it done.
Old - 95 EF Falcon Gli i6 - Argon Silver
New - 03 BA Fairmont Ghia i6 - Blue Pearl
efbeggza is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 03:34 PM   #8
tommo74
zx TT
i have 18's with superlows and yeah id definately recommend the camber kit...i paid about 200 bucks from bob janes
Da LTD,3.9 ltr. 21.2 sec quarter mile.109 rwk
300zx Twin Turbo,Stillen intercoolers,boost controller,19 inch speedies,boost guage,dvd,mps,hands free phone,diamond black,leather interior.
12.8 quarter mile.243 rwk
tommo74 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 04:47 PM   #9
EDXR6T
yer n e lower then low's u'l need camber unless u like going thru tyers:P
go the shims thats wut i got on mine and ther fine dont wurry about ajustable un les it's going race specs no point
if u wana go the cheap rout go low's ant the front and SL's at the bk still looks low and no camber needed (fully sick commo specsLOL)
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 05:13 PM   #10
335JET
@jas_23_
335JET's Avatar
thanks for the replies
who would i talk to about getting the shim type and can i install it myself and would i put it on while the springs are off
Old 11-02-2006, 06:52 PM   #11
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
i got my camber kit from repco.
try your local wheel and tire shop they should be able to supply and fit.
i wouldnt fit it yourself becuase you need a wheel alignment with it.
BA MK2 XR6T
