Old 14-06-2015, 07:57 PM   #1
gra
gra's Avatar
Default hazards but no indicators at all
hello there a friend has a 99 au falcon forte i think and they need to replace the clock spring as the horn and cruise no longer works the indicators were playing up by flashing fast but we figured that one out but the other day after using a trailer (same trailer used on same car for years) now the indicators are not working at all the hazards are flashing just the indicators are not ive checked the fuse but thats not blown
im at a loss any help would be grateful
cheers
gra is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2015, 08:10 PM   #2
11ford11
Default Re: hazards but no indicators at all
replace the fuse for FLASHER -
make sure hazard switch is turned off correctly as this cuts flasher circuit
check trailer for short
Old 14-06-2015, 08:48 PM   #3
gra
gra's Avatar
fixed was looking at the fuse box diagram upsidedown lol
had the trailer hooked up to my car 2 weeks ago and all was good
cheers for the help
Old 15-06-2015, 06:59 PM   #4
gra
gra's Avatar
not fixed
replaced fuse but 1 km down road it blew again
Old 15-06-2015, 08:29 PM   #5
revcore
revcore's Avatar
Had the exact same problem when I had my ED Futura. Borrowed a plasterboard trailer from Bunnings to cart some timber home and ever since then I encountered the very same problem you are experiencing. Never did find out why it did it. I ended up trading it in for a EL Fairmont wagon.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2015, 10:23 PM   #6
11ford11
Originally Posted by gra View Post
not fixed
check trailer plug hasn't pulled out/loose wires inside/not burning on exhaust-
do you remember which blinker was on when it blew ?
Old 16-06-2015, 08:33 AM   #7
gra
gra's Avatar
found fault the wire assembly is in the boot (installers too lazy to attach underneath) a teenager had taken trailer off to push it down drive as friend couldnt reverse trailer (female) then the friend didnt double check the trailer before driving off (still female) and i think the cord was too short hanging out of boot and when cornering it found the weakspot the plug on the car and ya all bar 2 wires snapped (females and trailers dont go together) thanx for all the help cheers to all
Old 02-07-2015, 03:30 AM   #8
gra
gra's Avatar
cruise control fault was fixed after replacing the clock spring at a wasted cost of 330 to find no difference it was finally fixed by replacing the actual horn/airbag piece on steering wheel 40 from wreckers
cheers
