when cruising along at about 60kph a wobbling sound comes from the rear drivers side wheel. I've come to the conclusion that a wheel bearing is giving out so have decided to replace it. Now I thought I knew what the job would entail until my 25yr old son told me to stop thinking old school. ??? Ok! So I look up on line what the bearing & hub look like and got a set off eBay for $99. Now I just need info on remove & replace. I have all sorts of pullers if needed. Just need a procedure PLEASE. Thanks, George
Au Falcon = Mr Reliable
Here you go George, a great how to by Stu (au11LTD), it was located in the Tech Docs section -
http://www.fordforums.com.au/vbporta...articleid=1143 Good luck with the job, share any tips when job done? cheer's, Maka
