Old 29-07-2015, 06:59 PM   #1
Kurtis1983
Exclamation Icc issues in bf falcon need help!!
I recently removed the icc from my bf falcon and now all dash lights will stay on and speedo don't work while my car is running also have no display on my icc screen. I was told the car has gone into stolen mode. Is there anyway around this issue without it costing an arm and a leg to fix? I have re-removed the icc to check for any broken pins, in which none are, and replaced it. Car will run but nothing in the icc works. I've checked all fuses as well. Is there anything I can do?
Kurtis1983 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2015, 09:35 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Icc issues in bf falcon need help!!
Hi. No such thing as stolen mode. Pull the ICC again and make sure that you havent broken the lugs that hold the plug in place in the dash. If it all seems secure you may need to "reset" the plug on the dash side by pulling on the white part so that it clicks out to mate with the plug on the ICC. Also check all the fuses for the ICC both inside the car and under the bonnet. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 30-07-2015, 06:38 AM   #3
Kurtis1983
Thanks I give it a try and see how it goes
