18-02-2006, 04:16 PM | #1 | ||
Boooostn'
Hi all,
I have recently aquired an ED XR headlight assembly (lights, indicators and grille) to put on my ED GLi wagon. When I removed the headlights to test fit the grille, the first thing I notice is that there are NO holes at all to mount it! I assume I will need to drill out holes in the radiator support rail for the top mount, and that doesnt bother me so much. What the main issue is, is that the bottom mount of the grille (the 10mm bolt cast into the plastic of the grille) has no where to go at all? It just sits out with no where to mount it on! Is there another bracket that I need to put this lower mount on? Am I just missing where it actually goes? Any info would be greatly appreciated! Cheers, Chris
2012 FPV GS Ute - Kinetic, Supercharged 5.0L, 6spd ZF auto, leather interior - The Boosted Daily! 1979 XD Fairmont Ghia - Silver, 302C V8, Full velour interior, slowly building her up to be a tough cruiser! 2002 Nissan Patrol ST - Desert Gold, 4.8L DOHC 6cyl petrol (Soon to be reequipped with a 5.7L LS1 V8), 5speed auto, lifted, locked, 33's, nature destruction vehicle! |
18-02-2006, 05:21 PM | #2 | ||
What you need to do is...
Fit the bloody EF XR body kit first :P :P
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
18-02-2006, 06:11 PM | #3 | ||
Chris,
there is a metal bracket that you are missing. it would be simple to make. It is simply a straight flat piece of metal that bolts in between the bumber and the body (on the 2 front bumper monuts. It then sticks up and there is another hole for the grill to bolt into. Getting the nuts on and off is a bit of a bugger as they are in a tights spot. I can scan the page out of the workshop manual if you need it... Cant take a pic as I wouldneed to remove my grill to do it... |
18-02-2006, 06:34 PM | #4 | ||
Picture a sheel ruler with 3 holes in it.2 for the bumper mounts and one for the grill..
18-02-2006, 07:58 PM | #5 | ||
The Brackets you require are STILL available from Ford as are the Harness connectors to fit the lights to the original Harnesses.
18-02-2006, 09:36 PM | #6 | ||
Number 5 is alive!
Chris, you could always sell the front to me.
:P
Kerry Tickford wings are for Tickford cars! "Experimental Racer" #6 1994 Gunmetal XG XR6 1997-1999 [B][COLOR=Red] 1994 Le Mans Red ED 2008 MA XR5 Mondeo 2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced |
18-02-2006, 09:51 PM | #7 | ||
The 'Stihl' Man
kerry if you are after a front I will be selling my old white one very soon, actually going to strip the car tomorrow night.
18-02-2006, 10:06 PM | #8 | ||
Number 5 is alive!
19-02-2006, 12:52 AM | #9 | ||
Boooostn'
bdennis - I have the EA-D factory manual also, but I couldn't locate where this bracket you talk about is, what page is it on? I will have a look and just fabricate one up. The standard loom will just plug into the headlight plug wont it? They didn't appear to be different at all!
I suppose I could get those parts from Ford if they are cheap. polyal - Damn, I wish I had known you had a white one before i got mine, I need one in stark white! but alas, I have two XR grilles, I should just not be lazy and spray one up lol
19-02-2006, 08:52 AM | #10 | ||
Number 5 is alive!
Chris, the brackets are a straight piece of steel, the bolt between the bumper and the chassis rail.
They are about 200mm long and have holes for the two bumper bolts, and teh grill bolt. That is all they are. I made a set for the XR front i sold out of 1.5mm sheet metal.
19-02-2006, 05:35 PM | #11 | ||
Chris, we can make some out of flat aluminium bar. Easy to cut and drill and no painting reqd.
19-02-2006, 05:55 PM | #12 | ||
Number 5 is alive!
The aluminium will be prone to cracking through vibration over time.
19-02-2006, 07:57 PM | #13 | ||
Boooostn'
good idea darin, or just some flat steel... meh it will be easy, we will just do it with whatevers laying around... maybe some plywood? lol
19-02-2006, 08:07 PM | #14 | ||
Number 5 is alive!
How aboutsome foam?
:P
19-02-2006, 08:11 PM | #15 | ||
Why not just BUY them? They are cheap?
19-02-2006, 08:18 PM | #16 | ||
Number 5 is alive!
Whats cheap?
19-02-2006, 09:16 PM | #17 | ||
Boooostn'
yeah how cheap are they? if its less than a piece of flat bar then no worries lol
19-02-2006, 10:59 PM | #18 | |||
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
19-02-2006, 11:21 PM | #19 | |||
Flat steel sounds the go then.
20-02-2006, 07:27 AM | #20 | |||
Re the wiring loom. As long as you have the small loom and plug set that connects the low and high beam lights together, the std loom will plug in just fine. Like this... |
20-02-2006, 08:36 AM | #21 | ||
Boooostn'
cool, yeah I have all that wiring! Cheers mate
20-02-2006, 09:27 AM | #22 | ||
this is the brackets you need, they are about $20 each from ford. |
