Old 29-11-2015, 10:37 AM   #1
NCII40
XR6T BA 2002
NCII40's Avatar
Default Water Wetter
Anyone Using this ATM,
Discuss the difference and benefits of water wetter over Glycol coolants
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2015, 11:30 PM   #2
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
Default Re: Water Wetter
It's good and does usually lower operating temps a little
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2015, 06:35 PM   #3
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks mate
Will it allow my engine to reach operating Temp though??
Runs at around 90 degrees atm
XR6T 2002 BA
Old 05-12-2015, 07:06 AM   #4
Jarry
Going with the X-Flow
Jarry's Avatar
I think your engine will still run at 90 with water wetter.
90C=195F=thermostat opening temp.
If anything, the temp would just be a little less likely to climb under hard use.
I noticed that the grade of motor oil I used had a greater influence on operating temp than water wetter. i.e. Engine ran noticeably cooler with 5w-30 as opposed to 10w-40.
For everyday use, I think water wetter's greatest benefit is that it allows you to run a coolant mix (giving corrosion and anti-freeze protection), while coming close to the cooling efficiency of 100% water.
Since it lowers surface tension, it will find leaks in a tired cooling system.
I would be reluctant to use it without coolant unless racing. See here
Jarry is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2015, 12:46 PM   #5
eed-250
eed-250's Avatar
need more regular radiator flushes. I wouldnt use it in a street car.
4.0Lturbo
T56
AP Racing
520rwhp
eed-250 is offline   Reply With Quote Multi-Quote with this Post
