19-04-2013, 08:22 AM | #1 | ||
Just another mock-up..
Hey guys,
I'm looking at fitting factory Sat Nav to an AU2 Fairlane. Now I'm just wondering if it's all plug and play. If I have the unit, loom and the disc player in the boot, does it all plug into the factory loom without needing anything else..? Has anybody attempted or achieved this modification..? Also, can you still get the current maps for the system..? Any help is appreciated..! Cheers
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
19-04-2013, 07:43 PM | #2 | ||
5.6L x 2 pilot
Not sure about the wiring Kris, but I do have maps as of Sept 2009. PM me if you go ahead with this project.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
19-04-2013, 07:48 PM | #3 | ||
meh.
I haven't attempted it, but I do know the dash is physically different, so is the wiring...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
19-04-2013, 08:21 PM | #4 | ||
5.6L x 2 pilot
It was a $5K option, so in a Lane, you would expect the wiring to be there. Actually, the wiring diagrams on here should tell you.
Let me know if you need me to take any photos Kris. Stu
20-04-2013, 10:53 PM | #5 | ||||
Cheers Stu, if I get stuck I just might hit you up for some pics.. I'll do a little more homework and see how I go.. Thanks guys..!
22-04-2013, 04:54 PM | #6 | ||
where can you get the center dash from and if you dont mind what is/was the cost.
Robert. |
22-12-2015, 10:59 PM | #7 | ||
XR6T BA 2002
I just bought a full sat nav kit with loom
i been searching around now and can't find any of the factory wiring? anyone know where it is hidden
XR6T 2002 BA
24-12-2015, 10:30 AM | #9 | ||
XR6T BA 2002
The 2 factory plugs behind the radio don't fit into the sat nav
Def not pre wired
XR6T 2002 BA
24-12-2015, 10:32 AM | #10 | |||
XR6T BA 2002
You gotta cut the ash tray fixing panel to fit this setup otherwise you cant push the radio back
XR6T 2002 BA
26-12-2015, 07:41 PM | #11 | |||
you basically need perm. +12v, switched +12v, Ground, speed signal, sidelights signal (dashboard/radio illumination) and reverse signal. you should not bother with the reverse signal unless you reverse 50 meters on a regular basis. speed signal will only be there if your car is a high specs one (eg Fairmont), if it is a low specs one like mine (Forte) you need to get the speed signal from the odometer cluster. NB you should not use the GND line on the radio harness (but rather any chassis point or the metal radio cage itself) as it can cause problems with the backlight of the tiny LCD panel of the odometer counter. Last edited by hellrc5; 26-12-2015 at 07:47 PM. |
26-12-2015, 09:13 PM | #12 | |||
XR6T BA 2002
Thanks for that I have a full loom that came with the package, but i assumed fairlanes were pre wired Its all fitted now, just no sat nav hooked up. I might sell it off and get one of those LCD gauges.
XR6T 2002 BA
26-12-2015, 09:20 PM | #13 | ||
fairlane was definitely were pre wired so as fairmont but even the low series falcons have a dedicated sat nav fuse (monochrome pictogram only vdo dayton pc3200/pc4000 was an option while high series and ltd and fairlane used the full grown colour pc5000) but I got no idea where the plug should be and has always been lazy to trace it back from the fuse box
27-12-2015, 08:36 AM | #14 | ||
If you do, please let me know. I gutting my wagon to redo the interior so the wiring might be a bit easier to work out.
Graham South of DARWIN NT AUIII Flash Cab project (nearing completion) |
27-12-2015, 09:59 AM | #15 | |||
XR6T BA 2002
Cool, I will be only selling screen, wiring and nav unit though I will still need the fascia and wood grain surround
XR6T 2002 BA
