You know that BMW M7 that BMW definitely doesn’t make? Well it still doesn’t. Because it makes the M760Li XDrive instead.
You thought that B7 Alpina was a bit of an animal? Well guess what - the new M760iL XDrive (don’t call it an M7) hacks out 600bhp and 590b ft from a 6.6-litre twin-turbo ‘TwinPower’ V12. That gives a 0-62mph time of 3.9 seconds and 155mph (limited) top speed. A bit like that Big Alpina. But lets not get into a comparison fight, because the official flagship Seven promises to be quite a thing. That silky all-aluminium V12 is tweaked by ‘M-Performance’ - note, not ‘M-Power’, which is a separate entity - and uses one monoscroll blower per bank of six cylinders. Mounted outside each bank, they breathe intercooled air and benefit from BMW’s usual Double-VANOS variable valve timing and ‘High Precision’ fuel injection. BMW says this allows for a higher compression ratio and contributes a good deal to throttle response and reasonable fuel and C02 figures: 22.4mpg combined and 294g/km are pretty good for an engine of this type. The prodigious torque is transmitted to the ground via an 8-speed auto with paddles and XDrive four-wheel drive with a defined rear-bias, a system that is no doubt the reason the M760Li can accelerate in quite so startling a fashion. Under 4 seconds to 62mph for a luxury limo is…. somewhat eye-widening. As is the fact that the thing has launch control as standard. And you’ll hear it coming this time too, with a quad-exit active-flap exhaust increasing the volume depending on the effort expended. Next Suspension is the same ‘Executive Drive Pro’ suite as on the standard 7-series, uprated for the M-Performance variant. So you get air springs with Dynamic Damper Control and Dynamic Drive to reduce roll and increase comfort, or tighten things up when you need to fling yourself down a backlane. It also features cameras that actively scan the road ahead and precondition the suspension settings, meaning speed bumps suddenly feel very, very remote." http://www.topgear.com/car-news/firs...-m760li-xdrive
CSGhia Last edited by csv8; 14-02-2016 at 12:44 AM. |
2 users like this post: |
Read that earlier today
Impressive Sent via HTC Velocity + [HolicsROM v1.3] [SWEEP2WAKE]
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
