26-02-2016, 03:43 PM | #1 | ||
Irregular member
Hi everyone, I am looking at doing an engine swap soon (V8 into VCT 6) and would like to confirm the following:
Are the air con compressors the same? (Seems to be.) To confirm, I don't need to swap them over as well, just remove from engine and move out of way before removing engine? Are the power steering pumps the same as well? To confirm, I don't need to swap them over also? Would a torque converter from an i6 BTR fit the V8 BTR? (I understand the stall speed needs to suit the V8, but I have a hi-stall and might use it again if possible.) Thank you!
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
26-02-2016, 04:48 PM | #2 | ||
Irregular member
I guess the first two questions relate to mounting, if they would mount back on the same (or require a bracket swapover) and match the pulley system, etc?
26-02-2016, 05:51 PM | #4 | ||
Irregular member
Thank you, MrEL. Much appreciated.
26-02-2016, 08:15 PM | #5 | ||
RIP...
A/C hoses are different too.
. Oval Everywhere... |
27-02-2016, 12:22 AM | #6 | ||
Irregular member
Thanks. There's whole bunch of differences, as I am using FAT245's list as a guide for this work:
http://www.fordforums.com.au/showthread.php?p=5279566
28-02-2016, 12:46 PM | #7 | ||
heres a non-relevant piece of info i found out recently, VCT serp belts fit onto the windsor perfectly
why the different part numbers i wonder |
