27-02-2006, 09:51 AM | #1 | ||
Girrrrr!!!
Anyone heard of this company? On the northside of brisbane.
Are they any good? The car is being taken there to be repaired under statutory warranty (one month after date of sale) I'm pretty sure the head gasket is gone, is losing water, lack of power, no oil in water... Is it possible for a head gasket to go without water contaminating the oil??? I can't see why not. Cheers Ashley
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
27-02-2006, 09:52 AM | #2 | ||
Girrrrr!!!
There is no leaks under the car either, this was obviously the first thing I checked for.
27-02-2006, 09:58 AM | #3 | ||
PM me if you want
does it have white smoke out of the exhuast.
I have seen welsh plugs go, they leak a little under pressure and the hot engine block evaporates the water so you cant see leaks.
27-02-2006, 10:52 AM | #4 | ||
Girrrrr!!!
There is a bit of white smoke, which evaporates quickly (like steam kinda?)
So I dunno. Gets worse when the car has warmed up. Either way they said they will pressure test it and go from there.
27-02-2006, 11:34 AM | #5 | ||
EF Fairmont Ghia
yes, it can blow between cylinders or out the side of the block, loss of compression but not actually through a water jacket so no water in the oil.
27-02-2006, 12:05 PM | #6 | ||
Girrrrr!!!
thought so...
I will update when I hear back from the mech a nicks this arvo... cheers fellas
