11-09-2005, 10:41 PM | #1 | ||
Low and Loud
Ive had a wierd issue with my old ladys's EA Ghia. (Series 1)
When we got it, the car ran REALLY cold. This was due to the previous owner drilling 4 holes into the thermostat. Im not sure why 4 but im sure they had a reason :yeees: I replaced it with a CPC thermostat and found the temp was errattic and the car tended to get quite hot with it. 3/4 way and creeping over driving time of 20mins I today replaced it with another thermostat which worked perfectly in my car with a good temp range but in her car caused it to again run cold. Barely goes near the normal area. Anythoughts? Seems that if I fit a decent thermostat it runs cold or a cheap one it runs hot.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
11-09-2005, 10:46 PM | #2 | ||
run a semi priced one. that should fix it
11-09-2005, 10:47 PM | #3 | ||
are the thermostats the same size?
11-09-2005, 10:50 PM | #4 | |||
Low and Loud
John your a funny one aint you? : LOL
11-09-2005, 10:56 PM | #5 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
11-09-2005, 10:57 PM | #6 | ||
Blown Head
Drill a 2mm hole into the side of the thermostat, that stops irridicate temp variations from occuring. All E-series and AU Falcons require this mod.
Oh yeah and make sure the thermostat you buy is the right temperature, it should be 92C from memory. |
11-09-2005, 11:24 PM | #7 | ||
Low and Loud
Currently the car has a 92deg "Waxpelt" style thermostat (thats the brand on it).
11-09-2005, 11:27 PM | #8 | ||
I always run genuine ford thermostats... Have had many troubles with aftermarket ones
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
12-09-2005, 12:18 AM | #9 | ||
I've also heard the best theromstat for the E series is the genuine one, and they aren't that dear.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
12-09-2005, 12:28 PM | #10 | ||
Former E-Series Member
Yep aftermarket is not worth bothering with. New genuine is dual stage and needs no mods to work properly.
12-09-2005, 02:40 PM | #11 | ||
Hmmmmm
My EA runs below the Normal range aswell.......always has since new, didnt think that it was abnormal
12-09-2005, 06:05 PM | #12 | ||
I just went and bought a genuine thermostat, only $14.50 or so plus $2 for the gasket, so not the most expensive thing in the world. Cheaper than the $25 repco one that was in my car... Doesn't seem to have fixed the temperature fluctuating problem I have though... :(
12-09-2005, 06:32 PM | #13 | ||
Blown Head
Drill a 2mm hole in the side of it... seriously this is the ONLY way to fix the fluctuating temp problem.
12-09-2005, 06:38 PM | #14 | |||
Hmmm Gold!!!
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
12-09-2005, 07:35 PM | #15 | |||
Mick, just buy a genuine one. Never had an issue with them. Besides the 6 week old one that siezed shut, but we won't go there. |
12-09-2005, 07:36 PM | #16 | ||
I'm still having the fluctuation problem with a genuine thermostat. Is it worth taking it back and trying another one?
12-09-2005, 08:05 PM | #17 | ||
02/90 EA II Fairmont
One of my genuine ones killed a headgasket, since i'd replaced a fairly old thermostat I just assumed the fluctuations were supposed to happen (since it was genuine and all)....
replaced the thermostat when i did the headgasket, and my fluctuations went away...
211RWKW EA |
12-09-2005, 08:25 PM | #18 | ||
Temp Fluctuations may settle down after a while too... One of mine was fluctuating quite bad but after a couple weeks driving it settled down.
12-09-2005, 10:09 PM | #19 | ||
Blown Head
Buubox drill a 2mm hole in the side and end all the arguments. This WILL fix your problem, of that I am 100% sure. You will then be able to tell the naysayers where to go!
Even Ford drilled holes into the AU Falcon thermostats on the first service. It stops temp fluctuations by allowing some hot water to reach the other side of the thermostat allowing the thermostat to not become victim of late opening due to the thermostat acting like a heatsink(hot water one side, cold water other side = thermostat that won't open until water is boiling hot). Also the small hole allows some water through meaning the water on the radiator side is allowed to heat up a little before the first thermostat opening. NONE of the thermostats can do this if they are completely blocked units. Instead they open up suddenly and push freezing cold water into your hot engine block and head, which can cause serious damage. Ford genuine thermostats, aftermarket thermostats, cheapie thermostats, it doesn't matter... for the E-Series to AU cars all require this mod. |
12-09-2005, 10:09 PM | #20 | ||
the only way i fixed it in my ea was to put a new radiator and gen ford thermostat
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
12-09-2005, 10:13 PM | #21 | ||
ea hooligan
what you have to remember on the ea they have a flow by system that actually do what you are saying so you shouldnt have to drill anything in them i was going to try it myself and my mechanic told me to get of the grass as they do it on an original thermostat
13-09-2005, 12:10 AM | #22 | ||
Shoot.
You will find that the genuine thermostats already have a small hole drilled through them, although it's very tiny (about one mm from memory). Mine fluctuates a bit and so does my friend's EA (also new genuine), but I am guessing mine might be something to do with the aftermarket water pump :S I might drill the hole out a mm or so and see if that helps.
20V Turbo |
13-09-2005, 07:57 AM | #23 | ||
GIVIT Rally 84 BARRA XE
I always drill one 3mm hole in mine, someone told me to do that years ago. Never had any issues with fluctuactions in any of my cars. It just allows a tiny amount of water through as was said above, to avoid cold one side hot the other.
More of a problem for the E series cars is the silt buildup problem in the radiators, had issues with the ED and mother's EF, clean out the radiator no more problem.
XT BF2 SZ BA XG E Outback Ute XE BARRA - http://www.fordforums.com.au/showthread.php?t=11382891 - 2007 GER Via Birdsville, 2008 via Broken Hill, 2009 via Cape York, 2012 via Karumba, 2014 via Innamincka, 2016 GIVIT RBR, 2017 via Boulia, 2018 Via Mighty Murray, 2019 Via Dig Tree, 2020 Via Thargomindah, 2021 Via Lawn Hill Gorge, 2023 Westmar - Gunnedah Sponsors, London Fire & Safe www.fireextinguisher-and-safes.com, G&D exhausts and suspension Beenleigh , Beenleigh Bob Jane |
13-09-2005, 01:07 PM | #24 | ||
Low and Loud
Yep its all sorted now ;)
Im still curious WHY someone would drill 4 1mm holes in the damn thermostat :S
13-09-2005, 08:51 PM | #25 | ||
Perforated edge ;)
211RWKW EA |
13-09-2005, 09:23 PM | #26 | ||
Couldn't find the 4mm drill bit.
02-03-2006, 02:17 PM | #27 | |||
First post. I bought a 94 XG ute on the weekend, and the temp won't move off the cold mark. So I'm picking up a genuine thermostat this arvo. Will I need to drill a hole for a XG, or only E-series and AU's?????? Cheers, Jase |
02-03-2006, 03:45 PM | #28 | ||
Well I had a new radiator in my EL. My mechanic who I have been a customer of for over 10 years now, reckons he puts 180deg thermos in ALL E's & AUs, he reckons that the factory 195 is way too hot. But why would FORD have put 195's in from the factory, they must have had a reason, & also if you look up a thermo chart the FORDS run the hottest, no other vehicle uses a 195 thermo.!
Bog stock EL Fairmont Wagon |
02-03-2006, 05:06 PM | #29 | ||
Oops, I slipped....
Putting colder thermostats in E-series will make them run rich, because they aren't at operating temp, so the ECU adjusts.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" Last edited by Aaron_EF8; 02-03-2006 at 05:25 PM. |
02-03-2006, 06:00 PM | #30 | |||
