Anybody had discs and pads replaced on their ST? Whats a good price? Recomended parts if not oem?
Ford wants $950 for oem. Pedders around $1100 but forget the brand. For reference its done 105k km. Not sure if thats early for discs, but i was told they are worn just below minimum spec. Only on its second set of pads though. |
Is this for front and back? Labor included?
For parts, Motorcraft front pads for an LW are only $48, Ford OEM are $99, I doubt ST pads would be hugely more expensive...try another dealer or go to a Ford Parts Superstore. |
Front and rear. Yeah pads are cheap. It's the discs I can't find part prices to compare to.
Mad Scientist!
Get in contact with site sponsor 'Race Brakes'
They will help you out |
![]() Join Date: Jan 2005
Has it got the standard 278mm front rotors (DBA2118E), or 300mm (DBA2120) ones?
Rears will be DBA2145. Ebay is your friend - I use ADB discs, but you could go for RDA or DBA DBA front 2120 T2s for $280 a pair: http://www.ebay.com.au/itm/DBA-T2-Sl...kAAOSwax5Yv7GF
It's standard. Not sure if that is 280 or 300mm on the ST.
But thanks for the part numbers and I will check with race brakes too. |
Chairman & Administrator
There were actually 3 rotor sizes available for the front: 278mm 300mm and 320mm.
Cheers Russ
Observatio Facta Rotae
From what I can work out, 320mm were on XR5, 300mm on ST, and 278mm on everything else.
#9 | ||||
Interesting. My rear brake set has stamped on the box compatibility with he following:
