Old 15-03-2006, 10:25 PM   #1
Peter Pan
Default Idle drops on hard braking
Idles drops to 250 RPM when braking suddenly and almost feels the motor is about to stall (rough idling) then vibrates its way back to around 550 RPM when stationary with foot on brake. Takes off OK. Can anyone help please? New to forum. 2000 AU Falcon Series 1.
Peter
Peter Pan is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 10:30 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
sounds like the booster diaphram or booster line as split or loose causing it to suck air from out side the system ...
Originally Posted by Riksta
Old 15-03-2006, 10:34 PM   #3
Peter Pan
Thanks - is this easily fixable?
