Old 13-08-2017, 09:26 PM   #1
Edxr6
Default Hood Insulation
Fellas,
How do you remove the plugs that hold the sound insulation under the hoods of the AU's.
Regards
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2017, 11:36 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Hood Insulation
From memory, just pull hard?
Old 22-08-2017, 01:26 AM   #3
snap0964
You'll probably end up tearing it - they do go a bit brittle from the heat.
Usually use a trim removal tool.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2017, 03:19 PM   #4
Mont5.0
Mont5.0's Avatar
i use a set of side cutters, just dont close the jaws all the way shut.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 22-08-2017, 07:29 PM   #5
Edxr6
Cheers fellas,
Regards
