Pursuit 250
I would to the headlights on & they would come on then flicker once or twice then stay on as normal.This happened a couple of times during the week then tonight i turned them on they flickered once then didn't come back on.I'm thinking switch.Whats the easiest way to test the switch ?
Any suggestions would be helpful. CHEERS
HODGIE Pursuit 250 |
Globe!
Hi. Could be the circuit breaker in the under bonnet fuse box. Get yourself a test light and check to see if you have power on 2 terminals of both the high beam and low beam relays. Cheers MD
Pursuit 250
Hey guys swapped a couple of relays around & found the problem.
The head light relay in the engine bays. Thanks for your replies.
