Old 01-03-2018, 08:43 PM   #1
au350hp
Default Save your drivers seat bolster.
After making a pair of virtually new front buckets out of 5 AU XR seats because of the typical side bolster wear and collapsed back support, I have come up with a way to slow the damage. Slide the seat back before getting out so you can pivot from the front of the seat avoiding dragging your legs and backside over the side bolster. Yes, it is a pia, but better than the tragic look of collapsed bolsters and not been held in the seat around corners.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2018, 09:13 PM   #2
Default Re: Save your drivers seat bolster.
One step ahead mate, with 3 position memory seats and only 2 drivers number 3 pulls the seat all the way back for the fat guy exit. I'm only small but it works a treat.
Old 01-03-2018, 10:22 PM   #3
Professor Farnsworth
Fossil fuel consumer
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
I'd much rather have the seat deteriorate over time than rearrange it every time I get out.
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2018, 10:40 PM   #4
NX74205
NX74205's Avatar
Does it automatically in my Mondeo
Current car:
2016 Ford MD Mondeo Titanium EcoBoost (2016-)
Previous cars:
2005 Ford BF Fairmont (2006-2019)
1989 Ford EA Falcon GL (2000-2007)
1982 Ford KA Laser Ghia (1999-2000)
NX74205 is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2018, 10:45 PM   #5
Having recently changed over the seat bases in my FG (as 99% of the time I am in the car by myself and the passenger seat is rarely used) from passenger to driver to distribute the wear after 100,000Kms....That is exactly what I now do!
I also rebuilt the side upright bolster with foam, which I described in detail in my Show 'N Shine thread....
Swapping seat bases & repairing weakened driver's upright bolster
I think because of the soft foam Ford use in the bolsters and coupled to the high driving position / low steering wheel, it forces you to squash the seat base bolster when getting in and out of the car with the less clearance, especially if you have thick thighs.
So to make the new seat bolster last longer, I slide the seat back when getting out, then after I get back in, slide the seat forward to a line I have on my console that aligns with the front of the seat base for quick and perfect repositioning.
Old 01-03-2018, 11:01 PM   #6
Dezza
Parts bin special
Dezza's Avatar
Well, that won't work for me! I'm 6"4' so my seat is always back!
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2018, 11:20 PM   #7
CoupeKing
Ohhh man up ffs
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2018, 11:36 PM   #8
Dezza
Parts bin special
Dezza's Avatar
Originally Posted by CoupeKing View Post
Ohhh man up ffs
Funnily enough my housemate has the same car (it's still a project). I can't say I've tried to sit in it yet!
Old 01-03-2018, 11:48 PM   #9
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
I repaired my front seats bolsters then put tight sheep skin seat covers over them, i make sure when jumping out of my xr not to put too much weight on that right side bolster.
I also taped up the frames with foam tape iirc where they were poking out of the torn bolster cover fabric lessening the sharp edge of the seat frame there, giving my good unripped seat covers a way easier time now.
My bolsters are still good & going strong, looks way better than what they were lol!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2018, 12:09 AM   #10
au350hp
Luckily, I am still agile enough to lower myself in & out without doing any adjustments. Seeing as so many cars have the issue and it looks so bad, I thought it will help some people.
Old 02-03-2018, 08:55 AM   #11
ebv8
ebv8's Avatar
i bought a passenger XR seat from ebay for $20, put the lower foam in my drivers side and boom, for $20 its a new seat... this was a while back so AU XR seats went cheap
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2018, 09:48 AM   #12
Cav
HUGH JARSE
Cav's Avatar
I have a big arrse, so everything wears evenly
Cav is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2018, 11:12 AM   #13
jmack
Last one i did i put a piece of carpet between the steel frame and foam.stopped the frame from cutting though it
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2018, 11:22 AM   #14
commodorenutt
commodorenutt's Avatar
In the FG the console side of the backreast has a wire frame, rather than the foam block (airbag size) fitted to BA/BF. I had the foam replaced under warrantly when it cut through on that wire (which had welding spatter on it, making it rough, and sharp).
I taped up the wire parts with cloth-reinforced tape (gaffer tape) then put that split loom tububg over it, and taped over it again. 5 years later, still no problems, so it's definitely worth doing.
I have also made some desk chairs out of various seats over the years - EB Ghia, BF Fairlane, BA Fairmont - on all of them I've smoothed all the sharp edges with gaffer tape, and none of them have any noticeable wear on the foam, despite some having 40+ hours usage each week.
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2018, 05:31 PM   #15
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
I'm very conscious of this at the moment. My old BA was pretty bad and I noticed it alot on alot of the FG's I was looking at.
Training myself to step into the new one at the moment, how long that lasts I don't know but its only a daily so hey...
My Au's not too bad but the Escort is a problem, very high bolster on the Scheel seats, small car and long legs are proving difficult. I don't look real stylish clambering in and out but I went to alot of effort to get the correct Beta cloth so thats the way life has to be.
Mk1 GT Cortina Project.
FG XR50 Daily.
