Old 20-03-2006, 09:15 PM   #1
nick Philliskir
EF94
Question Help with ID of opt20
Can anyone tell me what upgrades have been done
on EF v8 falcon GLI with OPT20 on ID Plate
nick Philliskir is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2006, 09:43 PM   #2
Fairlane
V8 Powaah
Fairlane's Avatar
Its a cop car
should have 3.23 LSD, Fairmont Interior Lighting (usually with a dimmer switch), Sports Suspension, Police Instrument cluster (similiar to the Fairmont one but with police calibrations) and most likely will also have ABS. It gives you a few tidy options which bring a little closer to an XR. Im actually instrigued that the police optioned up a Gli with a V8. Im guessing that it may be a WA police car (by the way is it white?)
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2006, 09:55 PM   #3
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
They also have different ECU with a different shift pattern.
I have an EF XR8 OPT 20
We should start a EX -CHASER thread to see who else has a chaser
Old 20-03-2006, 10:54 PM   #4
TwistedEL
TwistedEL's Avatar
Welcome Nick
I have an ex chaser. For now
It's the only EL I have owned so I'm not 100% sure the differences between Gli and police pack but I know for sure there is adjustable speedo, oil cooler, ABS, LSD, dual airbags, better shift patterns and slightly better electrics.
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 08:40 PM   #5
nick Philliskir
EF94
Default cluster panel
Yes it is white
how much diffence between the Fairmount custer & police custer panel
how do you adjust it
Old 21-03-2006, 08:55 PM   #6
347Stroker
347Stroker's Avatar
Same TCU, so shift patterns are not changed. ECU has no speed limiter, and will have steel tail shaft.
KOEO, hold button for odo in, and wait till it says speed, can be adjusted up or down to 20%
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 09:07 PM   #7
nick Philliskir
EF94
what is adjusted up or down 20%
Old 21-03-2006, 11:30 PM   #8
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
I read somewhere that a chaser trans wont change into 4th until it is over 65ks so i figured that was just a different control module and mine also seems to have a firmer change than any other ford ive driven
Old 22-03-2006, 12:10 AM   #9
347Stroker
347Stroker's Avatar
The speedo. You can adjust as to what it reads
Old 22-03-2006, 12:20 AM   #10
apolloxbgt
cross breeder
apolloxbgt's Avatar
No v8's have the speed limiter do they?I thought only the 6's had them.
apolloxbgt is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 12:22 AM   #11
347Stroker
347Stroker's Avatar
Sure do....even my XHXR8 5 speed has one!
Old 22-03-2006, 12:27 AM   #12
FairmontEL
Driftin shopping trolleys
FairmontEL's Avatar
Yep thats right and has more aggressive shift points i used to have one of these ecu's
VZ Calais 5.7ltr cammed, stalled, and the rest.
04 BA XR6T ute
FairmontEL is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 12:29 AM   #13
347Stroker
347Stroker's Avatar
None on the Ford database, no different part numbers listed.
Workshop manuals show nothing, and MINE is exactly the same as other cars I own, so in EL it DEFINATLY is no different.
Old 22-03-2006, 12:42 AM   #14
FairmontEL
FairmontEL's Avatar
well ur wrong
04 BA XR6T ute
Old 22-03-2006, 12:44 AM   #15
FairmontEL
FairmontEL's Avatar
i could definatly feel it didnt go into 4th under 65kms and was quite a bit different to the stock ecu i had
maybe u have a faulty or fake excop ecu
04 BA XR6T ute
Old 22-03-2006, 12:53 AM   #16
347Stroker
347Stroker's Avatar
Nope. Mine is not faulty, or fake. Mine is an XR8 from Tumut NSW and I have owned it since Nov 98. I still have the TCU on the shelf, as it was converted to manual. There is only 2 TCU modules for EL series V8 Falcons. ELGT/FBT, and everything else.
I have every Tickford EL V8 model here, from Concorde, ELGT, FBT, ELII XR8 and XHII XR8....care to rethink your "u r wrong" statement?
Old 22-03-2006, 12:55 AM   #17
347Stroker
347Stroker's Avatar
And just to clarify something, the FBT will go into 4th under 65kph with the gearbox set in Max Perf mode.....
Old 22-03-2006, 12:55 AM   #18
FairmontEL
FairmontEL's Avatar
maybe its because mine was a 6cyl and not an 8.. becuase there is definatly a noticable difference between the stock 6cyl ecu and the cop 6cyl ecu.. v8's must be different..
04 BA XR6T ute
Old 22-03-2006, 01:23 AM   #19
Psycho Chicken
Psycho Chicken's Avatar
6 cylinders have a different trans program. V8s don't.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 03:55 PM   #20
Fairlane
V8 Powaah
Fairlane's Avatar
Still dont know about the ECU thing. I had a QLD Police Detective car (purchased from Bryan Byrt, Mt Gravatt) and it used to shift into 4th under 65km/h and in fact it felt like every other EL BTR 4 speeder.
Old 22-03-2006, 04:56 PM   #21
TwistedEL
TwistedEL's Avatar
I've never cared to look but I'll watch on the way home to see when it shifts to 4th and post up tonight. 4 litre ex police car.
Old 22-03-2006, 09:27 PM   #22
EF_Frmnt
EF_Frmnt's Avatar
Are you lot talking about 4th or overdrive? Because holding it in 3 on the shifter will infact hold it to 4th gear but it wont go into torque convertor lockup and hit the high overdrive.. overdrive usually kicks in at about 70ks in my EF auto and its a totally standard box and ECU.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 11:49 PM   #23
TwistedEL
TwistedEL's Avatar
Economy: 4th 60-65 lowest I could get it
Power: 4th 80-85 ditto
