Hello one & all, I have a 2004 st170, I have a problem, there is a cable on the right hand side of the engine that is moving constantly backwards & forwards while the engine is running, it is very annoying, doesn't seem to effect the running of the engine. I can see it moving, any ideas please ?
![]() Join Date: Oct 2006
Are you sure the engine and transmission mounts have not failed causing the engine to move more than it should and pull on the cable.? See https://www.youtube.com/watch?v=iJsIDKP02xE and https://www.youtube.com/watch?v=WRM5hH679uI etc
regards Blue |
Or is it this https://www.youtube.com/watch?v=ZmhYdl4HXf4
regards Blue |
Not engine mounts, new ones were installed recently. I can see the end of the cable moving independently backwards & forwards.
#5 | |||
regards Blue |
Or is it this https://www.youtube.com/watch?v=ZmhYdl4HXf4 this is it,any idea what that is ?
Broken DSI actuator clip. See https://www.focusfanatics.com/forum/...-clip-fix.html
regards Blue |
