Old 21-12-2015, 04:32 PM   #1
Sprint347
Tickford
Sprint347's Avatar
Default AU IRS LSD 3.45 to 4.1
Hi All
I've done plenty of searching but with limited success.
Has anyone here installed 4.1 gears into an AU IRS LSD?
I'm guessing M78 Dana Spicer gears are suitable for this application?
Is there a speedo cog available for this ratio to suit BTR 4 speed?
Thanks in advance.
S
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2015, 04:57 PM   #2
ebgtjames
Need More Cubes!
ebgtjames's Avatar
Default Re: AU IRS LSD 3.45 to 4.1
Jarad has 4.11s...
http://www.fordforums.com.au/showthr...1253752&page=7
1992 EB GT
418 Windsor, T56 Magnum!
Engineered/Modification Permit!
STREETBUILT Racing
1993 DC LTD
EB GT Drive Line!
ebgtjames is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2015, 05:11 PM   #3
T MAN
T MAN's Avatar
i have not done 4.11 but i have 3.91..
4.11 are available, but just like the 3.91 the 4.11 are actually m75 dana gears, dana spicer only make them in m75 series.
all this means is the pinion needs to be shimmed for fitment in our m78 housings.
and unfortunatly there is no speedo gear big enough for 3.9 or 411 gears. the largest made was a 23 tooth which is ment for 3.45 ration with 16" low profile tyres.. this can be used on larger rims for 3.77 ratio but its still around kmh out...
so a speedo corrector would be the easiest way to get around it...
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2015, 06:47 PM   #4
NCII40
XR6T BA 2002
NCII40's Avatar
Hey Mate
I would highly recommend a guy who built my Diff, His name is Glenn (GJV Automotive) 0431557226
He did an excellent job on my 389 LSD upgrade and he knows BW Diffs..
He has a ebay store too, His username is Vicmelboz thats i how i found him
He does 4.11 to and knows how to modify them to fit
XR6T 2002 BA
Old 21-12-2015, 08:50 PM   #5
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Should be able to fit an internal 7 tooth gear to sort the speedo.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2015, 08:53 PM   #6
T MAN
T MAN's Avatar
Hmm. Never thought of trying that.. is there a 7 tooth available for the btr?...
Old 21-12-2015, 08:58 PM   #7
Sox
RIP...
Sox's Avatar
As far as I'm aware there is.
Oval Everywhere...
Old 21-12-2015, 11:20 PM   #8
mcfly94
mcfly94's Avatar
Im on dana 3.9's and a precision helical lsd.
As TMAN said there a 75 series set shimmed to suit our 78 series diffs.
I couldnt find a gear for life of me searched high and low, american forums, australian forums. Gave up installed a speedo corrector, drove around for like 3 months got sick of bashing the limiter on WOT and installed a QH and made some adjustments.
Now all good!
Id upgrade your diff centre while your at it!
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2015, 09:21 AM   #9
Sprint347
Tickford
Sprint347's Avatar
Thanks everyone for the replies.
I saw Dana spicer gears advertised as m75, m76 and m78 which was confusing. I've since discovered they're effectively the same (m75 has slightly smaller outside diameter and m76 is IRS) but they're interchangeable.
I do have a Quarterhorse, I didn't realise that can do speedo calibration too.
Hopefully I'll get secure some gears today and get the ball rolling - first gear in BTR autos is terrible.
BA XT
Old 22-12-2015, 12:57 PM   #10
mcfly94
mcfly94's Avatar
QH can calibrate Trans only speedo corrector still required. Placement of one however can eliminate the need to make adjustments in the trans
Old 22-12-2015, 04:25 PM   #11
Sprint347
Tickford
Sprint347's Avatar
Awesome cheers, just reading into the Jaycar speedo corrector devices now.
I've purchased a set of 4.1 spicer gears - can't wait!
BA XT
Old 22-12-2015, 05:45 PM   #12
mcfly94
mcfly94's Avatar
Yeah don't bother with them I got rid of mine. Wouldnt pick up au signal as they changed the model. Unless you can get hold of the older model.
My auto electrician end up using there own was $120 in comparison to the jaycar $40 and much larger, dunno what brand it I'd but it works!
Old 14-01-2016, 03:00 AM   #13
347 mont
347 mont's Avatar
Aaaahhh that's why we couldn't get the Jaycar corrector to work on my AU11, ended up taking
it to an auto electrician to fit and still had no success. Interesting.
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2017, 11:41 AM   #14
NCII40
XR6T BA 2002
NCII40's Avatar
Solved
https://www.fordforums.com.au/showthread.php?t=11464112
XR6T 2002 BA
Old 02-07-2017, 07:37 PM   #15
Bossxr8
Peter Car
Bossxr8's Avatar
A place like gauge works who calibrate speedos should be able to sort it out even if factory gears aren't useable. They got my speedo spot on after i went 3.9's.
Old 25-02-2019, 04:08 PM   #16
Climaxxx
Did you notice a big difference in gears? Was thinking of changing to 3.73. What do you need to make the speedo work properly?
Climaxxx is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2019, 10:30 AM   #17
Bossxr8
Peter Car
Bossxr8's Avatar
It felt stronger with the 3.9's. Economy around town improved as well. Didn't notice any real difference to highway economy either.
It will just need a change in speedo gear to get the speedo right.
