Old 04-03-2019, 09:31 PM   #1
Default AU Carpet/Underlay
I've made some effort to find the answer, but no dice (or I've looked wrongly). The floor is now bare, in my assaying of water leaks and repairs needed.
AUII, under the driver's feet only, is a different underlay with rigid PU foam encapsulating a steel lamination.
Questions about it.
1. What was the idea behind it - radiating catalyst heat?
2. Do they all rust, or is it just this particular car again?
3. Did this carry into the B-Series cars?
Old 04-03-2019, 10:17 PM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: AU Carpet/Underlay
Questions about it.
1. Yes.
2. If they have leaked badly (which they can through the broken spot welds of the pedal box) they can rust as any car can do.
3. Not sure. B series floors are different though.
Old 04-03-2019, 10:27 PM   #3
Ta, have read about the spots pulling through, traced back the oxide staining on the top of the pedal box top brace and yep, there were the torn welds under my scuttle trim. I suspect this only happens with manuals and high mileage autos.
I do feel that the person who said "Hey, let's wrap bright steel in a porous foam and put it on the floor of an everyday car!" was a bit misguided.
Old 06-03-2019, 12:14 PM   #4
Ratio adjustment underway. Started with 85% rug, 15% coffee, now 98% carpet and 2% clean(ish) water. Leaned on the forecast of a hot Mon-Wed for optimal drying.
Old 06-03-2019, 01:33 PM   #5
macman
macman's Avatar
That carpet is revolting. But that is also OH SO SATISFYING. Looking forward to seeing the clean, dry version.
O.T - any interest in Citroens?
macman is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2019, 02:02 PM   #6
Oui. Although I try to stay on the blue oval here.
Was unimpressed to find once the carpet came clean, a plethora of butt-burns from flicking bumpers towards the pedal box. It's just plain grubby - why not use the ashtray?
Old 07-03-2019, 11:43 AM   #7
Newbie type question: Is it readily possible to put the carpet back in with the dash in place, or is this a mission and a half?
Old 07-03-2019, 02:03 PM   #8
macman
macman's Avatar
The carpet definitely can be put back in place with the dashboard already completely assembled and installed.
You may find it easier to slit the carpet in the trans tunnel hump area, to get it around and past the centre dashboard supports, where it bolts to the hump/floor. If you have a bucket seat/console car, this should be fine as the console covers it.
Dashboard removal isn't a bad job, but it's complicated and time consuming, so there's no way I'd remove a dashboard simply to reinstall my carpet.
Old 07-03-2019, 04:53 PM   #9
Ta, the dash came out first and by the timing of things will be ready to go back in before I'm done with the carpet and underlay.
With a competent helper, I think the complete dash is actually one of the easier I've encountered to RR.
