03-04-2006, 11:50 AM | #1 | ||
Parts bin special
Well, for most of the summer I thought my aircon needed regassing, until recently on a hot day I tried the aircon... and it worked! The air was cool. This has now happened a couple of times, but most of the time the air has been warm, so I'm thinking that some sort of temperature controller is the problem, as the climate control doesn't seem to be very consistent with its temperatures. I'm wondering if anyone have had similar problems and whether they have any ideas.
BTW. I did a diagnostic test, and it didn't come up with any error codes.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
03-04-2006, 12:14 PM | #2 | ||
I'd get some holy water, a cross and chant "the power of christ compels you" before turning it on.
Seemed to work in the movies... - John |
03-04-2006, 12:18 PM | #3 | ||
Hey mate, next time I'm up your way, I'll send a PM. I've got my old CC unit sitting in the cellar and it ran 100% perfect before I swapped it for a black EBII unit.
You can test that out, and if it turns out that your CC unit is bung, you can keep mine. (But if the problem persists, I'll take mine back :P) The sunlight sensor (or whatever it is), which is a little opaque bulb that sits in the middle of the top/front of the dash at the base of the windscreen, between the driver's side and passenger's side airvents, might not be operating properly. This may cause issues with the CC. It usually is an issue if you have a dashmat which covers this sensor. A cheap fix would be to cut a little hole out of your dashmat (if you have one) so that sunlight/radiant heat can reach this sensor. Cheers matey |
03-04-2006, 12:33 PM | #4 | ||
The one and only
You could have a blockage.
Have a look at the AC pipes in the engine bay, see if any are excessive hot or cold.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
03-04-2006, 12:59 PM | #5 | |||||
Parts bin special
04-04-2006, 10:12 AM | #6 | |||
04-04-2006, 03:14 PM | #7 | ||
Parts bin special
Well. Since today is fairly warm, it was a good chance to see if the dashmat covering the sensor was the problem. I took off the dashmat, and the air was the coldest it's been for some time! That may have been the problem. I guess time will tell. Thanks Dave!
04-04-2006, 06:34 PM | #8 | ||
No probs :
Just repeat this on some other warm days to see if its a constant thing. Also, on warmish nights try the same thing. |
