05-01-2020, 08:09 AM | #91 | ||
Have you seen how light the F150s are? They are aluminiun now and are pretty close to Ranger weight.
Just noticed they list the F150 they tested as 2400kg. Ranger Raptor is 2330kg.
05-01-2020, 11:59 AM | #92 | ||
I've noticed that that a larger capacity atmo engine generally gives better economy when
towing than an Ecoboost engine which needs part throttle enrichment to avoid detonation. Also, if Ford put an Ecoboost into a really heavy truck like a Super Duty, it would be constantly under part throttle fuel enrichment and using a lot more fuel than a large V8. A petrol V8 towing anything is always going to use plenty of fuel but with enough basic capacity like say, a 5.0 litre may be enough to keep it away from rich mixtures and mitigate the hit on fuel economy like the large Ram Gasoline Pick ups. Last edited by jpd80; 05-01-2020 at 12:10 PM. |
05-01-2020, 02:59 PM | #93 | ||
05-01-2020, 04:20 PM | #94 | ||
Facts are the V8 Ranger will be good for at least low 14s, depending on what spec engine they use.
06-01-2020, 03:27 PM | #95 | ||
Peter Car
06-01-2020, 08:49 PM | #96 | |||
I am not sure if anyone knows the answer or the question is beneath some, but is the current motor in a Mustang a 'coyote'? or is it different and if so, is it smaller, lighter etc than the engine that was used in the attached video of the Ranger V8 conversion.
Fords I own or have owned: XW UTE, XW FAIRMONT, XT GT, XT Fairmont, EF XR8, XH XR8 UTE, XH XR8 UTE, AU UTE, Renault Scenic, XF UTE, BA XR8 UTE, TERRITORY, Chrysler Voyager, WS FIESTA ZETEC,TERRITORY TITANIUM, BA UTE, Nissan Pathfinder, AU Falcon Forte, BA XR8 UTE. |
06-01-2020, 09:08 PM | #97 | ||
Yes, Mustang has 3rd generation Coyote.
The Miami is a locally engineered blown version of the Coyote, and is sometimes referred to as the Coyote. Considering the engineering behind it it should be distinguished by using the Miami name. |
2 users like this post: |
06-01-2020, 10:37 PM | #98 | |||
3..2..1..
Will be lighter as it doesn’t have a supercharger sitting on top of it. Size wise it’s much the same. |
07-01-2020, 10:50 PM | #99 | |||
Where to next??
___________________________ I've been around the world a couple of times or maybe more....... |
07-01-2020, 11:49 PM | #100 | ||
Here's a crazy idea, what if the V8 has been engineered to load from underneath....
what would that do..... |
08-01-2020, 12:32 AM | #101 | ||
BLUE OVAL INC.
So its $36k to modify a Mustang and this is a complete transplant which they expect will cost more.
Surely it'll be in the vicinity of 120k plus, even if they give credit for the 2.0l Now im sure some will think im just kicking Ford here, but if its 120k or up for a Ranger I don't see how its any different to the argument against the Camaro by some who suggest the premium isn't justified when you can just buy a Mustang for 30k less, well, you can get the bigger RAM for 40k less. |
08-01-2020, 12:53 AM | #102 | ||
It's a shame it wasn't going to be offered in a lower spec Ranger, and not just the raptor.
08-01-2020, 01:07 AM | #103 | |||
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock |
3 users like this post: |
08-01-2020, 02:41 AM | #104 | ||
What if the engine can be fitted on the production line....
08-01-2020, 07:37 AM | #105 | ||
So would this be 4wd or 2wd, Raptors are built to go off road, so what driveline will suit Coyote, just can't see current 4wd setup taking V8 power. Hope i'm wrong, this (v8) might sway me into one.
08-01-2020, 08:51 AM | #106 | |||
Basically what people were paying for in a full size RHD converted Pick up |
08-01-2020, 09:12 AM | #107 | |||
on the production line and complete the units there. I find the timing of this project interesting, the utes actually timed to arrive with barely 12 months to run on this product cycle. Last edited by jpd80; 08-01-2020 at 09:27 AM. |
08-01-2020, 10:46 AM | #108 | ||
But the Raptor wouldn't be replaced straight away in the new model would it?
08-01-2020, 10:49 AM | #109 | ||
Former BTIKD
Straight LPG?
08-01-2020, 10:55 AM | #110 | ||
Could it be a test run for the T7?
08-01-2020, 11:08 AM | #111 | ||
08-01-2020, 11:16 AM | #112 | ||
Former BTIKD
Calling it 'gas' I thought you might be one.
08-01-2020, 12:01 PM | #113 | ||
BLUE OVAL INC.
Then its a factory RHD V8 dual cab ute and should cost little more than a Ram.
But its not, at this stage its a factory backed modified Raptor which is going to cost in the vicinity of 50% more than its nearest competitor which begs the question, whats the point if you can get a Hemi V8 in a bigger ute with a better towing capacity for 80k. Don't get me wrong, I still think it will sell, im just highlighting the hypocrisy that HSV we're slammed for offering something GM/Holden fans would want because it cost 30k more than a Mustang, yet this is ok because it carries the right badge. Last edited by BENT_8; 08-01-2020 at 12:07 PM. |
08-01-2020, 12:16 PM | #114 | ||
08-01-2020, 12:34 PM | #115 | |||||
If they change the frame set up for a V engine, the power train can be installed down the line. After the engine, the 10R80 and transfer case are all common with the 2.0 diesel's 10R80. Once in place, we know that the engine fits in conversions already done so if Ford adds the power train during production, the rest of the hook up is less problematic. Quote:
A V8 Ranger Raptor is unique niche vehicle, you've pointed out several times that a post factory conversion is going to be expensive. I simply question why Ford would sanction that when the next gen Ranger will be less than a year away. All we know is that Ford has a V8 Ranger plan, none of the usual suspects knows anything, the next logical thought is maybe Ford does it themselves... Quote:
08-01-2020, 12:53 PM | #116 | ||
Watch this Ranger assembly video and see how the engines are installed on the frames, when the body is married to the frame, the inner guards are not in place so maybe those get slammed in place inside the wheel wells... |
08-01-2020, 01:00 PM | #117 | |||
BLUE OVAL INC.
The Camaro is an unlimited post factory production vehicle, this is being marketed as a limited edition, Ford speak for grab your ankles. |
08-01-2020, 01:07 PM | #118 | |||
BLUE OVAL INC.
I don't think anyone doubts the ease of which a V8 could be fitted during production, the question is, will Ford US sanction it for our small market as i doubt they'll want it to compete against F150 in their market or will they continue to give us the green light for 'limited edition' conversions. |
08-01-2020, 01:09 PM | #119 | ||||
There is no marketing, just a rumor. All i'm saying is that there's a better way than following what everyone else is doing... Quote:
but, What if the engineering on the next gen T6 allows this to happen.... What if the yanks say yes please to both V8 Bronco and V8 Ranger Raptor. Last edited by jpd80; 08-01-2020 at 01:16 PM. |
08-01-2020, 01:14 PM | #120 | |||
BLUE OVAL INC.
They're the less equals more profits car company, remember. |
