Old 25-07-2013, 12:09 AM   #1
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Default Handbrake major service kit - worth a try?
I was sick of my (AU2 IRS) handbrake needing adjustment every few months so I thought I'd try the 'Major' kit offered by PBR - part number 'PBK132'.
Found it on eBay for $10 from a seller called 'marineauto'.
It's a very comprehensive kit which will hopefully stop the adjusters winding themselves off, as well as replacing the torn rubber boots around the lever that comes in though the handbrake plate.
Now the bulk of what you need to know has already been covered in Wooshas thread: How to Adjust or Replace Hand Brake (IRS) so I'll just add couple of points that shed some light on the fitment of the new parts.
Most of them bolt in and are very hard to get wrong. Use graphite grease within the mechanism of the handbrake and also a smidgeon on the 'backing plate' where the pads sit.
The springy tangy thing that holds the adjuster wheel from winding back in is the only part worth any explanation - it needs to be drilled out and the new ones fitted with the supplied pop rivets so you'll need a hand riveter, a cheap one will do.
Stripped...
Cleaned. Push a rag through the little cylindrical housing that's there. use a small screwdriver perhaps and push'n'pull the rag to clean it up. Push it through to the back as well to be sure that it's all nice and tidy. Go on, you'll feel better for it.
The rivet, I've started to drill it out then stopped for a pic. If it starts spinning, just continue to drill but on an angle and then don't push too hard (as you want it to keep spinning so it drills evenly) - it will work just fine.
Rivet and clip removed. You could no doubt have imagined this but I took the damn pic and even put an arrow in there before I realised it was a bit daft so just humour me ok? ;)
The new springy tangy thing fitted. Do your best to get it in straight as the axle hub gets in the way somewhat. If you have a bulkier pop rivet gun than I do then you may struggle.
Wooshas thread covers the rest so I'll leave it at that. The new shoes are MUCH grippier than the 12 year old ones that came of it so the handbrake is reassuringly affective.
I'll update this thread when it next needs the handbrake adjusted to give an idea of whether or not this has resolved my issue of the handbrake not retaining it's adjustment.
Al.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 12:22 AM   #2
Lajon
Default Re: Handbrake major service kit - worth a try?
Can you please post the ebay listing of this as i can't seem to find it!
Lajon is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 12:29 AM   #3
Silver'
Silver''s Avatar
Sure, it will be out of date soon enough, but it doesn't hurt to have it here now eh?
Hmm, it's gone up $9.10 since I bought mine.
PBR Park Brake Major Repair Kit Ford Falcon AU Handbrake ...
I originally found it with the search "au major handbrake kit" if that helps anyone on here months down the track.
I just spotted the BA kit which has a lot more bits in it - including what look like large springs to centralise the brake shoe. So I'm figuring that maybe the carpark scrape scrape scrape noises are something that is always going to be a niggle...
TE2 #116
Old 25-07-2013, 08:51 AM   #4
madmelon
Do you really mean you got it for $10 or is that a typo? I bought mine at discounted staff prices through a major parts retailer and it was just under $90.
My handbrake has jammed on a couple of times so I figured it was time to refresh it all- especially since the dust boots are destroyed. Haven't got around to installing it yet though.
Thanks for the info!
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 09:42 AM   #5
Silver'
Silver''s Avatar
Definitely a typo! It was $120, now $130.
TE2 #116
Old 25-07-2013, 12:54 PM   #6
Polyal
The 'Stihl' Man
Polyal's Avatar
Mate credit for you doing this stuff yourself, oh I wish I had some more time. My car is due for a service next month so this will get done.
Im sick of pulling my handle up so high it feels like Im going to touch the roof, and Im sure its sticking now and then too.
Thanks for the info.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 06:50 PM   #7
GK
Walking with God
GK's Avatar
Thumbs up Re: Handbrake major service kit - worth a try?
Is that per side or for both rears?
OK, just checked the pictures above, for both sides! LOL!
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 25-07-2013, 06:51 PM   #8
Silver'
Silver''s Avatar
Kit does both sides
TE2 #116
Old 30-07-2013, 10:00 PM   #9
Polyal
The 'Stihl' Man
Polyal's Avatar
Well I just bought the kit, car is due for a service so ill just ask them to do it. Thanks for the heads up.
Old 01-10-2013, 10:42 PM   #10
Silver'
Silver''s Avatar
I'd adjusted the handbrake too tight at the wheels when I fitted the kit and was getting some lovely harmonic groaning, particularly when reversing. It's hard to look cool when your car sounds like that hehe
So on the weekend I finally got around to adjusting it as per the instructions (duh!) which is all the way off then tighten it a quarter of a turn. This has completely sorted it so happy days.
The adjustment seemed to hold up well over the last two months but I'd like to see it last almost a year before I'd call the kit a cure. Fingers crossed...
TE2 #116
Old 10-10-2013, 02:01 PM   #11
bloggs24
I bought this kit finally after putting up with a handbrake that always needed adjusting, always had a rattle, always had a squeal, and couldn't hold the car even on the slightest incline. This kit solved all those problems, and i put it in about 8 months ago with no issues yet.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2013, 05:03 PM   #12
rmack
rmack's Avatar
The Au wouldn't hold and had started to make a grinding sound. So installed this kit in August and all came good. Having a working handbrake is a plus...
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2018, 03:33 PM   #13
Silver'
Silver''s Avatar
This PBR 'PBK132' kit is now available from Bosch. Same part number. I thought that I should update this in case anyone's trying to find the kit.
p.s. five years later and still no problems with adjusting, or having the handbrake scrape, so the kit is good.
TE2 #116
Old 12-12-2018, 04:01 PM   #14
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Good work Silver!! Yeah i put a PBR major h/b kit through mine a little while ago & not a skerrick of noise or grief since lol, definitely worth doing.
cheers, Maka
Old 12-12-2018, 05:10 PM   #15
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Great update, Thank You
UK
Old 13-12-2018, 06:45 AM   #16
xeeclipse
That stopping plate behind the adjuster is rubbish. I tow things sometimes and I'm getting real tired of the adjuster unwinding and having to rest the car on the park sprag.
xeeclipse is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2018, 05:47 PM   #17
FTE-063
FTE-063's Avatar
Hey Al I can't find the kit on ebay where else can you get it from ??
Few seconds more looking again on ebay there sold out
Cheers Dean
FTE-063 is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2018, 06:14 PM   #18
Silver'
Silver''s Avatar
Cheers Dean
I'd try Repco, Bursons's etc. DartAUxr8 just used a set as a part of his epic IRS rebuild, so they must still be available?
https://fordforums.com.au/showthread.php?p=6228388
Might be worth putting a kit through it - or did you already do that and the replacement one is no good?
TE2 #116
Old 20-01-2020, 03:38 PM   #19
Edxr6
Guy’s,
If someone knows where I can purchase a kit from for $120 or $130 please let me know. I have been quoted $200 in some of the Repco stores in Sydney and Bosch isn’t producing the kit anymore.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2020, 06:03 PM   #20
Peuty
Afterburner + skids =
Peuty's Avatar
You're doing better than me mate, I couldn't find anyone who could supply them at all.
Oo\===/oO
Old 20-01-2020, 07:09 PM   #21
Edxr6
One Bursons store in QLD quoted me $360 + postage. Another item to be obsolete for the AU’s in the very near future.
Cheers Peuty
Old 28-01-2020, 04:59 PM   #22
Edxr6
Guy’s,
Paid $150 at Repco, they had it retailed for $200, the salesman was a gem. Now for the install.
Old 19-07-2020, 07:57 AM   #23
Daviem73
Brilliant thread so helpful. Quick question is can anyone point me to the major handbrake kit today as the l8nks are out of date. If they are still available. Cheers
Daviem73 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2020, 09:51 AM   #24
Edxr6
Daviem73,
Ring Repco and see if they have any left in their system. Bosch has cease making the Kit. There was a couple left in QLD when I was making enquiries, they wanted big dollars.
Good luck
Old 19-07-2020, 11:48 AM   #25
Daviem73
Originally Posted by Edxr6 View Post
Daviem73,
Good luck
All good . Wanted to do proper job but as the only major fault is a completely seized adjuster on one side just ordered that on eBay.. much appreciate the reply.
