21-02-2008, 08:36 PM | #31 | ||
you have dirty injectors
21-02-2008, 08:39 PM | #32 | ||||
Cheers, Jeff http://www.aufalcon.com/ubuxkl |
21-02-2008, 08:42 PM | #33 | |||
At the service they did in January, they hooked up the computer and it didn't return any faults. What a pain. The damn thing drives beautifully but I hate having things like this : :
21-02-2008, 08:43 PM | #34 | |||
Next upgraded Mk1 Leopard
UK
21-02-2008, 10:42 PM | #35 | |||
Dirty or leaking injectors do not show up any codes.
21-02-2008, 11:52 PM | #36 | ||
AU's tend to get loosening of the inlet manifold bolts, which gives the same sort of symptoms as a buggered inlet gasket, so it's worth getting a size 10 spanner and giving the ones you can get to a good tightening.
22-02-2008, 11:44 AM | #37 | |||
22-02-2008, 05:57 PM | #38 | ||
Mine starting doing this when I got an aftermarket exhaust. Haven't been able to work it out yet. I've replaced the coil pack, oxy sensor, plugs and leads so I know they aren't involved.
23-11-2020, 03:09 PM | #39 | |||
Nitro
I was about to say adjust the throttle body stop screw like I did and for me it stopped the rev hang when stopping and all the hesitation disappeared just from a little turn of a screw....after all the new components I replaced ISC TPS coil packs leads plugs hahaha for me it was just a 1/4 turn of the stop screw and she idles and drives beautifully now.. Anyway going to go and check myself into a mental institution now my brain is fried. |
23-11-2020, 08:27 PM | #40 | |||
regards Blue Last edited by aussiblue; 23-11-2020 at 08:34 PM. |
21-01-2024, 08:22 AM | #41 | ||
my au xr6 hesitates at idle and runs perfect i squirted soapy water around the rear of engine between the gap in the inlet manifold and it instantly ran on 5 cyclinders. whats going on ?
21-01-2024, 11:18 AM | #42 | ||
Looks like you've found a vacuum leak.
If you weren't looking for a vacuum leak. Why would you be squirting soapy water on the engine? What did you expect to happen? |
21-01-2024, 10:45 PM | #43 | ||
someone mentioned inlet manifold leak and said to use soapy water in a squirt bottle im hoping its an leaking injector.at least i can tell the mech what i did when he comes to pick the car up once before ive degreased the engine and hosed it off with no problems
22-01-2024, 07:51 AM | #44 | |||
#neuteredlyfe
An inlet manifold gasket is a lot cheaper and easier to fix being a $25 job and takes about an hour to replace if you don't know what you are doing. |
22-01-2024, 11:28 AM | #45 | ||
thanks. thats great news i thought it was the other way around i drove it today and it was good. no problem but i know it will re surface iread that the gasket is a common fault
