Old 12-02-2024, 12:17 PM   #1831
GTLEGEND
Originally Posted by mad2 View Post
Hi GT. as promised a pic of BA/BF & SX/SY steering rack boots. aftermarket tho.
hope that helps someone out.
GTLegend - it 'appears' to be the rod.
cheers
Thanks,
But sometimes I dont trust aftermarket. Soemtimes they make two into one when they really should be two seperate parts.
Could be right but I would prefer to see genuine ones compared.
GT
Old 19-02-2024, 02:40 PM   #1832
phildee
phildee's Avatar
Still possible to get the engine side of the filter fuel line for a BA XR8 ute? Nut is seized in the filter and rounded off.
Cheers, Phil
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2024, 10:04 PM   #1833
GTLEGEND
Cheers, Phil
Hey Phil,
Long gone, part number BA9289K if its any help..
GT
Old 20-02-2024, 02:52 PM   #1834
frankie86
Sprinting Everywhere!
frankie86's Avatar
Hi GT, any of these left anywhere? BGF04178A
frankie86 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2024, 09:26 PM   #1835
XR Martin
XR Martin's Avatar
Cheers, Phil
Should be the same as every other BA Falcon? Unless the V8s are different?
But utes, sedans and wagons are all the same.
2004 BA wagon RTV project.
Old 20-02-2024, 09:56 PM   #1836
GTLEGEND
No good all long gone!!
Old 20-02-2024, 10:10 PM   #1837
GTLEGEND
Note quite, there were 4 different ones, below are the decriptions and part numbers. Basically for Falcon V8's and Utes Same, 4.0 Sedans and Wagons same.
BA9289A: ALL 4.0 ENGINES SWB SEDANS & WAGONS
BA9289K: ALL 5.4 V8 ENGINES SWB SEDANS AND ALL UTES (REGARDLESS OF ENGINE).
BF9289A: 4.0 FAIRLANE
BF9289K: FAIRLANE/FAIRLANE G220/FAIRLANE G8/LTD, 5.4 V8 SOHC EFI 24V
Old 20-02-2024, 10:30 PM   #1838
XR Martin
XR Martin's Avatar
The one I pulled out of a wreck ute looked exactly the same as the one in my BA wagon, maybe I should double check k.
Old 20-02-2024, 11:21 PM   #1839
mad2
Regular...with metamusal
Hi Legend ....
wondering what you could tell me re what's in the pic. i have NO idea. Thanks
it's not easy finding 'inexpensive' FG ute diffs.....
anyway thanks for your time GTLEGEND
Old 22-02-2024, 07:22 AM   #1840
frankie86
frankie86's Avatar
Hi GT sorry to bother you again, my sprint has broken 2 of these centre caps. ER2Z1130A, how much would I be looking at? Cheers
Old 22-02-2024, 01:07 PM   #1841
GTLEGEND
Hi Legend ....
So its a solid axle diff housing, number does not come up in usual places so trying to see if I can pin point exactly what it is off. Leave it with me for a while.
Old 22-02-2024, 01:10 PM   #1842
GTLEGEND
$55 each plus postage if required.
Old 22-02-2024, 04:35 PM   #1843
mad2
don't worry about it GT .. someone mentioned what it was off. thanks tho
Old 22-02-2024, 09:51 PM   #1844
GTLEGEND
Curious, I want to know now too..
Old 23-02-2024, 11:44 AM   #1845
mad2
will pm you latet
Old 24-02-2024, 09:17 AM   #1846
GTLEGEND
Hi Legend ....
Found it eventually:
AXLE ASSY - REAR, WITH M78 SERIES AXLE, TAG ID:5R29/R* (UTILITY, ALL 4.0L N/A ENGINES (VCT), 3.23, REAR AXLE LESS LIMITED SLIP DIFF, 4 WHEEL ANTI-LOCK BRAKING SYSTEM) Built from 1/10/2005 on.
Old 24-02-2024, 09:25 AM   #1847
mad2
thanks GT.
yeah so it's not suitable for my project.
Old 28-02-2024, 11:39 AM   #1848
T3rminator
T3rminator's Avatar
G'day GT, need your help please.
Do you have the fuel pressure regulator part number for the 5.4L 24v (Barra 220)?
Do you know if they are 3 BAR or 4 BAR?
Thanks!
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2024, 02:42 PM   #1849
GTLEGEND
Thanks!
Hey mate,
Part number XR3Z9C968AA.
For the life of me I cannot find the spec, I can find 32V at 4 Bar, but the 24V is not listed??
GT
Old 04-03-2024, 01:01 AM   #1850
Magnum_dogholes
Hi GT I was recommended to ask you from another member, I'm in need to know how many chassis bolts that the BF falcon has in total? And also their length and head size? I've tried google but haven't had any luck, thanks in advance for any help 👍
Magnum_dogholes is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2024, 07:58 AM   #1851
GTLEGEND
Hey mate,
Realistically there are no chassis bolts on a BF as it is a monocoque design with no chassis as such.
You need to be a bit more specific on which bolts you are referring to. I may be able to give quantities, but I doubt I could give length and head bot sizes, maybe some thread sizes but that's it.
GT
Old 04-03-2024, 12:46 PM   #1852
Magnum_dogholes
Makes sense why google had nothing either, thanks mate! A bloke was asking me in regards to getting a quote for a 1 or 2 inch lift on my bf sedan. I'm not sure if that helps? I believe he wants to put spacers of some sort of something to achieve this. In addition. You wouldn't happen to know the best way to achieve this? Thanks again mate
Old 04-03-2024, 02:26 PM   #1853
XR Martin
XR Martin's Avatar
RTV front-end will give you a 70-80mm lift, bit it's a lot of work.
Not sure what you would do with the back-end on a sedan though.
1" is doable with just a thicker top spacer and taller springs.
Old 04-03-2024, 06:04 PM   #1854
mad2
Hey mate, SX SY SZ SZ2 AWD Guard badges are all the same and are still available $55 each plus postage.
Hi GT. just replying back re AWD badges. ended up buying 5 from Jefferson Ford.
Thanks tho.
Old 04-03-2024, 07:03 PM   #1855
GTLEGEND
I would be asking a suspension specialist on doing that modification, taller springs and shocks would be a possible start but that just opens a can of worms as to what else needs to be done. Drive shaft angles and other issues will surely arise. Not impossible, just be ready to tackle issue after unexpected issue.
Old 04-03-2024, 07:04 PM   #1856
GTLEGEND
Thanks tho.
All good, glad you got them.
Old 09-03-2024, 03:15 PM   #1857
glitchedfolx
Hey GT, chance you'd be able to help me find something?
Would you have any clue where I'd be able to buy both side mirrors for a Ghia variant BA Ford Fairmont without costing an arm and a leg.
I've searched almost every wrecker in town, and scrapped the internet trying to find working replacements, only thing I managed to find was an eBay listings for both, but it either costs too much or my standards are too high
Location Australia Wide doesn't matter as long as postage is available, and I'm willing to cover both product and postage.
Appreciate the help!.
Thanks!
glitchedfolx is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2024, 03:27 PM   #1858
GTLEGEND
Thanks!
Hi mate,
You need to be a bit mores specific. Do you mean the whole mirror assembly or certain components. Whats you budget and where are you located.
A VIN will help narrow dow the exact part number too.
GT
Old 09-03-2024, 03:36 PM   #1859
glitchedfolx
Hi mate,
GT
I would probably say just replacing the entire assembly, since one mirror is held to the assembly by tape, and the other has snapped.
I'm located in WA, but buying parts from other states I'll be fine as long as I got postage. Budget I'd probably say around 300 total (150 each) before postage.
VIN: 6FPAAAJGSW3D50626
Hope this helps!
Old 17-03-2024, 03:12 PM   #1860
Bobman
Regulator
Bobman's Avatar
So many Genuine parts are Made in China now, it's disappointing.
Even "Genuine" BA headlights as we know are made by TYC, with Ford stamped on the back. Terrible, cheap and nasty compared to the Hella ones.
SZ Territorys seemed to have considerably more Chinese Genuine Ford parts than SX/SY, e.g. floor mats, air con condenser. It's a real shame.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
