Old 26-12-2020, 06:33 AM   #91
Armageddon
Default Re: The Definitive AU Diff Topic
Originally Posted by Dave_Obsession View Post
Thread-mine time.....this has been bugging me for some time, so I asked the guys at Etheridge Ford about AU diffs...
I got the following response this morning from the service manager:
So does this mean that any AU 3.45 diff will fit, regardless of whether the donor car was IRS or live axle - since it's only the diff centre that's being changed, it's all good? Or am I missing something here - is there anything else that would be changed over???
I have an AU series 1 option 20 with live axle LSD and 3:45 gear ratio...so I believe the dealer info is correct.
Armageddon is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 03:38 PM   #92
Ben
Ben's Avatar
Looking at putting 3.9s into my manual 01 xr8.
Obviously not something that I will do myself. Will go to a specialized shop on the GC looking at Nerang Diffs. But curious what causes some Diffs to become noisy after changing gearing.
Unsure where I will get the gears from but am hoping Mal Wood still offers something that would suit.
Besides finding the correct speedo gear what else will I need to have the job done or anything else that should be sorted while its opened up.
Cheers.
2001 AU2 220 XR8 - Build thread
Ben is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 05:51 PM   #93
mcfly94
mcfly94's Avatar
Cheers.
Genuine Dana spicers gears can be obtained in 3.91 they are actually a m75 gear set that are supplied with a spacer to fit the m78 housing. Probably around $500 mark for gears.
Noisy diffs generally comes from re-using gear sets after a wear pattern is formed, it’s hard to replicate it. I had no noise in my 3.91 true trac and still don’t after some km.
No speedo gear available for the 3.92 gear set; will need a 4 pin 12v speedo corrector that interrupts the VSS signal to cluster yet supplies the unmodified signal to the EECV.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2023, 03:42 PM   #94
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Apologies. Thead mine of the decade.
Did any AU XR sedan come with a live axle?
I thought the live V IRS was in this thread, but it is not.
I am currently planning an upgrade for an AU2 Forte, so 3.08 be gone!
Stu.
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 21-08-2023, 08:08 PM   #95
MrEL
Sick Puppy
MrEL's Avatar
3.45 LSD centre from an IRS will go straight into a solid housing.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2023, 08:13 PM   #96
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Not into a 3.08 housing which my Forte currently has. They are quite visually different.
So I guess that leads to my next question. Where there any AU sedans with a live axle that was not a 3.08?
Stu
2002 AU II LTD
Old 21-08-2023, 10:05 PM   #97
PG2
#neuteredlyfe
PG2's Avatar
HP XR6s came with a live rear axle.
Old 22-08-2023, 07:47 AM   #98
ebv8
ebv8's Avatar
Stu
the IRS 3.45 centre only will fit in the live axle housing but its only series 1 & 2 XR6 and all XR8 that were LSD, ghia's got the 3.45 but no LSD or series 3 XR6.
there are lots of factory ford ratios for live axles but all crap
3.08, 3.23, 3.28, 3.45... its not really worth the effort unless you can find a bolt in effort. go a 3.9 ratio, talk to a diff shop
i went from 3.08 to 3.45 and i think it was 0.1s quicker to 100kmh
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2023, 05:48 PM   #99
mad2
Regular...with metamusal
Stu
i have at least three 3.45 ratio AU diffs here that will fit any AU fitted with a solid diff.
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 28-10-2024, 07:50 PM   #100
Drifta-X
Bringing back an old thread
I recently got a 6wheel 1.75t au series 2
After going through this whole thing
I’ve worked out I have a 3.23:1 hd lsd
The manual has 3.45
Trying to find one of those centers might be tricky, where else should I look?
Drifta-X is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2024, 07:56 PM   #101
mad2
The manual has 3.45
for the 3.23or the 3.45?. where are you based?.
Old 29-10-2024, 09:42 AM   #102
Drifta-X
i have the 3.23 hd lsd
would like to fit 3.45 hd lsd (one ton manual i believe they came i)
western suburbs of melbourne
Old 01-11-2024, 08:19 PM   #103
George V
Stu
Live axle LSD 3.23 in AU2.
Regards, George V
George V is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2024, 11:35 PM   #104
mad2
i don't actually know - so you will have to find out..... cannot the centre from one [3.45] fit the other [3.23]?. for my AU2 wagooon i just swapped the 3.23 diff out for a 3.45 diff.
