Old 14-06-2006, 01:40 PM   #1
parker
Default Changing the leads
I'm about to try and change the leads on my AUII egas. I've had a bit of a look and you can barely see the coil pack and only really reach it from below and then you cant see anything.
Is there a trick to making it easier?
parker is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 01:49 PM   #2
DJL351
XR & FPV Owner
DJL351's Avatar
Remove the complete Air Box Assy... 5 or 6 10mm bolts is all.
When that is out of the way, you can reach through to the coil pack.
Make sure you know the order before you remove the leads.
Closest to the motor and closest to the fans is number 1 lead, closest to the Air Box is lead 6. (from memory)
D :
2005 BF GT (6sp manual - Build #183)
2015 SZ MkII Territory Titanium
2016.75 LZ Focus Sport
probably the stupidist post on aff - congrats
Originally Posted by flappist
There was once a time when every young man in this country was familiar with firearms and many owned them privately along with a stock of ammo and some bush gear.
Now the best we can hope for is to unfriend them on facebook then SMS their commanders with !!!1!!!!!!11!1!! and then finally plank a tank.......
DJL351 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 03:26 PM   #3
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
i put mine up on ramps and did it from under the car. was a bit awkward though and i had someone up top disconnecting each lead so i could follow it down and replace them one by one
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 03:55 PM   #4
parker
Just did it via the airbox method. Lucky I've got long arms
Thanks
