Old 21-06-2006, 02:42 PM   #1
henz79
Default How do you know the tappets are faulty
Ive got the rack and rocker out but now they all look the same to me. How whould i know one is faulty....... THANKS BOYS
henz79 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 08:42 PM   #2
hako
hako's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Regularly gives valued, considered advice to others.
I think you have to detect any faulty tappets with the motor running otherwise as you say "they all look alike". In a workshop they can do a "leakdown" test on each individual tappet which will identify any that have problems but this is hard to duplicate in your shed. If the tappets weren't noisy before you pulled it apart then thay should be OK. They should go back in the same bore they came out of.
hako is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 08:49 PM   #3
MIEF9640
MIEF9640's Avatar
Arrow rockers
It sounds like you are talking about an e-series 3.9 or 4.0lt motor and not an x-series crossflow with lifters and pushrods you need to confirm what motor you have before checking the problem and asking for possibles what will happen is you will get the wrong info and still end up none the wiser.. :monkes:
MIEF9640 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 08:59 PM   #4
LUXO_8
windsor user
considering he's asking in the eseries section, and he has said he has the rocker rack out it certainly sounds like he's got an OHC 6 to me
Old 21-06-2006, 10:37 PM   #5
Growler
Growler's Avatar
I think it's a chick asking so 'he' does not go into this equasion. :Reverend:
Growler is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 10:39 PM   #6
MIEF9640
MIEF9640's Avatar
Question Tappets
T : HATS RIGHT BUT IF THATS THE CASE THEN HE/SHE HAS ALREADY BEEN LED WRONGLY AS THE LIFTERS ARE NOT IN THE BLOCK AS I AM AWARE . BIGGEST PROBLEM IS THE ROCKERS ARE NON ADJUSTABLE ON E-SERIES . THAT IS WHY HE WAS ASKED TO CONFIRM HIS MOTOR FOR ADVICE . :
Old 22-06-2006, 05:16 PM   #7
henz79
Sorry Boys, ive got a 3.9ltr engine EA..... Ive put in a EF rack which bolt in no probs.... but the tapping noise is still there.. thats why i ask how can i find out which tappets is faulty cause they all look the same...... maybe ill just change all the tappets.....
