Old 22-06-2006, 05:14 PM   #1
TimXR6
Default fitting BA 17s
evening all
Picked up a set of BA 17s to put on my EF. I have hub adaptors from my 18 inch Zenettis.
heres the dilema-
the lip on the adaptor wont fit into the 17s because the rims have a small ridge on them. The easiest way around it is to grind the lip off the adaptor but i dont really want to tamper with them. Should i take to the rims with a dremel or is it something best left to the pros?
Tim
for those thinking about the unsafe and illegal adaptor lecture, dont bother
TimXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2006, 05:31 PM   #2
TimXR6
will also add that the adaptors are 37mm thick. is this the size commonly used with these wheels?
Old 22-06-2006, 05:57 PM   #3
Sweet_EL_
can't u just the the ba rims with the ef offset??
oh yeah, sorry, i have no idea about adaptors/spacers...
I didn't insurance places liked em..
Sweet_EL_ is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2006, 05:58 PM   #4
Simmo
White Lightning
Simmo's Avatar
yeh mate i took the dremel to my rims actually. ground the lip a bit all the way round on the inside of the rim. then they went on perfectly.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2006, 06:56 PM   #5
TimXR6
if its good enough for you simmo its good enough for me.
cheers mate
Old 22-06-2006, 07:41 PM   #6
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Hmmmmm dremel, what not just take a hack saw to them, lol.
Guess if you have re-treads on them then go for it as they are already stuffed.
Arent wheels the feet of your car, just as important as brakes, love to see how many weights are going to be stuck on them after you "dremel" them - so they are balanced. :1syellow1
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2006, 08:09 PM   #7
TimXR6
everyones a comedian. _ point taken though.
I could see it being a problem if i was playing with the outer edge of the wheel but i doubt there would be a real balance problem with taking a little from the centre of the wheel.
Old 22-06-2006, 08:11 PM   #8
crannersEL
crannersEL's Avatar
You could have bought Ba copies in 17" and 18" made to e-series off set which saves alot of muching around and keeps the insurance companies happy too
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2006, 09:06 PM   #9
TimXR6
they were a good price so i jumped on them. Thought it would be straight forward. adaptors dont bother me, never had any hastles before. might still sell them and get my zenetti repaired
Old 22-06-2006, 11:13 PM   #10
Sorted
Sorted's Avatar
Good to see some one can take a joke - cheers dude
I thought Adapters are legal is some states anyway(not vic I know that much) so thats not really the issue
If it works and they sit flat and are balanced then there shouldnt be an issue except for the obvious (Insurance/Roadworthy)
PS they are very nice looking rims
Tuned by DYNOMOTIVE
Old 23-06-2006, 12:11 AM   #11
TimXR6
thanks for your reply hemi. I will probably run them until i can afford a better arrangement, without adaptors.
I dont know you bud, how was i to know you were joking? sounded smart to me. I suppose you get that with the internet
Old 23-06-2006, 12:29 PM   #12
Sorted
Sorted's Avatar
I was cool with your reply thats what i meant
I was saying its good to see some one can take a joke (it wasn't sarcism)
meaning you can take a joke..........
Tuned by DYNOMOTIVE
Old 23-06-2006, 02:24 PM   #13
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
If you're going to grind the rim, make sure you do it very slowly, bit by bit. If you take too much off, the rims won't sit on the spigot (the round thing in the middle of the hub) and then weight will be taken by the wheel studs, which IS dangerous.
You also might want to consider re-sale, if you grind them, they won't be safe on an AU-BF....
Old 23-06-2006, 03:41 PM   #14
Simmo
White Lightning
Simmo's Avatar
the amount i took off was pitiful. seriously no more than a minute with the standard brown dremel grinding wheel.
