Old 19-08-2006, 04:02 PM   #1
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
Default List your Db
was in a sound comp today and had a thought of wot other people get decibel wise please list your subs, amp, Db and wagon/sedan.
2 x 12's - 700w amp - 135.5Db - wagon
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 04:44 PM   #2
micksta
micksta's Avatar
where can i get it tested ? as i'd go and test it today
micksta is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 04:47 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Using a dodgy sound meter that came on my phone, i get 110Dd, of undistorted sound. Never really tried how loud it can go though, starts distoring after 110.
PS, i have pioneer deh7750 head, pioneer yellow cone splits, and a set of old home theather speakers in the rear
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 05:05 PM   #4
04RSD
shinanigans
04RSD's Avatar
im a fitter from autobarn mackay in my old EB falcon i had a dehp9350 controlling a avhp7300dvd which all ran yellow pioneers splits, kenwood 7*10s running 50 - 180 hz in custom pods in front doors, ****ty clarions for rear fill kx 400.4 ( i think ) running splits and 7*10s this system made 129.5 db with subs off.
in the boot i had a pair of L7 15" solobarric kickers running off a pair of kx 1200.1s
tuned at 25hz for normal music, swap ports for 45hz and made 157.2. on old system
the subs were in 9.5 cubic ft box with a pair of 1.3m 6" ports
last week i dummied 1 sub and 1 amp into my girlfriends fiesta in a prefab box made 144.1 on the new system
04RSD is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 05:45 PM   #5
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
ummm. strathfield does it and maybe autobarn. will co$t tho...
EF Wagon Project:
Old 19-08-2006, 07:20 PM   #6
Rmyers
Does Steve have a car?
Rmyers's Avatar
I hit 139.9db (or 139.8, i forget :P) with my old setup. That was a single 15inch rockford fosgate power HX2 sub in a sealed enclosure powered of an alpine MRV1507 amp.
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 02:32 PM   #7
ned
Once shy... twice bitten
ned's Avatar
Yeh I'm keen on getting mine tested as well, you sure that autobarn and strathfield test them?
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 07:41 PM   #8
SwEeT Ba
Automotive Electrition
SwEeT Ba's Avatar
x1 JBL 12" 275rms, kenwood 2ch 300rms bridged amp, sealed box 65Lt = 135.5
:eclipsee_www.bseries.com.au/sweetba:
Sweet BA
SWEET
www.gdauto.com.au
SwEeT Ba is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 07:57 PM   #9
Walkinshaw
Two > One
Walkinshaw's Avatar
141.6 on Termilab (8cuft ported box)
139.9 on Termilab (2cuft sealed)
Single 15" Orion XTR with 300wrms in an EA with LPG.
Old 20-08-2006, 08:50 PM   #10
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
not sure about autobarn but last i knew strathy definatly did
EF Wagon Project:
Old 20-08-2006, 08:52 PM   #11
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
thats pretty good! my mate has a '85 corolla with the same sub, 560w max 4ch bridged amp but the girl didnt enter "i dont wanna blow it up..."
EF Wagon Project:
Old 20-08-2006, 10:29 PM   #12
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
if your in Melbourne and want to get your db tested enter a comp then you will have it tested professionally and have it on paper.........
see attached thread:-
http://www.fordforums.com.au/showthread.php?t=58825
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 10:49 PM   #13
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
[QUOTE=DRHEMI]if your in Melbourne and want to get your db tested enter a comp then you will have it tested professionally and have it on paper.........
feel cheated now. i didnt get any physical evidence :( except a photo of the leader board
EF Wagon Project:
