18-11-2005, 09:45 AM | #1 | ||
Supes
Ford All petrol engine vehicles since 1986 will operate satisfactorily on E10 except as listed below.
The following models may not operate satisfactorily on E10 fuel because of drivability concerns: Focus (2002 - 2004), F-series (1986-1992), Ka (All), Maverick (1988-1993), Mondeo (All), Transit (1996 - 2004). The following models do not operate satisfactorily on E10 fuel: Capri (1989-1994), Courier 2.0L & 2.6L (All), Econovan (pre-2002), Festiva (All), Laser 1.3L, 1.5L & 1.6L (All), Raider (All), Telstar (All). http://www.fcai.com.au/ethanol.php/2.../00000001.html
Yes I DO drive a Toyota |
18-11-2005, 02:48 PM | #2 | ||
Clio 182 CUP!
Yea.... the new Shell Extreme has Ethanol, but its only E5, so the benefit of the extra octane could still help.....
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
18-11-2005, 03:14 PM | #3 | ||
Old enough to know better
But the extra octane won't help unless you're tuned for it, or have a knock sensor, and I don't think the Focus has a knock sensor
18-11-2005, 03:33 PM | #4 | ||
Supes
nope...pretty sure the LR Focus does not have a knock sensor.
19-11-2005, 02:54 AM | #5 | ||
Zoom Zoom
It has a knock sensor but is not tuned to advance timing beyond the 95 RON tune on LR I believe, it will only retard it if a lower grade fuel is used. Fiesta however will advance timing to suit higher grade fuel AFAIK.
It is only warned on Focus, anyone is welcome to try it and see, I might try it out one day. I've never even used Optimax. ALWAYS used only 95 RON and as soon as Caltex Vortex 98 is available in Melb, I'll switch to it (Caltex Fuel card user).
2012 Mazda3 MPS
22-11-2005, 01:42 AM | #6 | ||
so optimax got ethanol? damn n i work @ shell (the servo) n i didn't even know that,....
but anyway guess i wont b filling up at work den.... so any other suggestion? i put vortex in once n result is no power.... 95ron i think it is... i find it slower to rev.. less power etc. n i drive on springvale road alot . So i need da power to take over trucks and slow cars... |
22-11-2005, 09:27 AM | #7 | |||
RDP #181
optimax extreme 100 ron i think is what he was referring to having ethanol
22-11-2005, 01:02 PM | #8 | ||
Supes
yep, think its only the 100RON that has Ethanol in it, not the standard optimax (or so I beleive)
22-11-2005, 04:24 PM | #9 | ||
I understand the LS Focus can advance as the various reviews state that you can get better power from higher octane...whether the benefits are worthwhile is another matter.
22-11-2005, 06:09 PM | #10 | ||
Clio 182 CUP!
Well.... ive just tried out Extreme.... gave the car a hard working. It seems to love it, going into redline with no dramas....
Hopefully ill see how economy goes and how this tank goes and then decide whether to stick with Ultimate or switch......
22-11-2005, 08:14 PM | #11 | ||
Supes
Teki,
what was the price per litre cost and the difference between 98 Optimax?
22-11-2005, 10:43 PM | #12 | ||
Clio 182 CUP!
120.5 for extreme...... and im not sure about the Optimax.... didnt check. But regular ULP was 107.9.... usually optimax is 9-10 cents dearer..... meaning its about 3-4 cents more?
08-05-2006, 10:31 PM | #13 | ||
Sorry to Thread mine (Saved me starting a new thread)
But has anyone disregarded the FCAI advice and ran their Focus on E10? Alternatively, has anyone found a E5 95 RON ULP? What would be the worst case scenario if i was to give it a run for a month as a trial? Heard Fuel lines/pumps/tank could be an issue? Or is it more engine internal's? Anyway, any food for thought appreciated Cheers Marty |
09-05-2006, 09:42 PM | #14 | ||
i ran mine on E10 from one of those El CHeapo servos (needed fuel real bad) The car ran like a peice of despite the fact the fuel pump stated it was 98 ron. I use octane booster in my car with optimax and it works bloody well
02-09-2006, 12:03 AM | #15 | ||
Any more Focus ethanol experience? The Qld govt recently announced it will be mandatory in all petrol in the near future.
MK |
02-09-2006, 01:11 AM | #16 | ||
Qld Govt states that the mandatory level will be e5 so you have no worries there.
02-09-2006, 09:28 AM | #17 | ||
Mr Focus
My 2003 CL sedan hates it, I would fill it right up and when I would go to work and back home the fuel would drop to 3/4 just like that.
Our 2005 CL loved it for some reason, it would give it more power but, my 2003 doesn't need any extra power. We don't use ETHANOL anymore. Mobil has the best fuel.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
04-09-2006, 11:34 AM | #18 | ||
Yes I have a 3 month old LS Focus Zetec and it has ALWAYS had E10 95 RON from united.
Absolutely NO problems whatsoever. I get over 600Km per tank and pay 4c / litre less than 91 RON... But no problems with this brew for over 10,000 Km now |
