Old 15-03-2005, 06:40 PM   #1
neb
hibernating
neb's Avatar
Default More problems.. !!
Hoping I can get some opinions on this.
I'm not sure if it's my engine or transmission.
When I've got the clutch pedal pushed in it is fine. When I let the pedal out whether it be in neutral or in gear I'm getting a pretty loud rattling sound. I was hoping it was my engine because I'm replacing it anyway.. but since the clutch is effecting it I'm thinking it might be the transmission or something related to that. I can't tell if the sound is coming from the engine or transmission.
Also I had a brand new PBR clutch put in just 2 weeks ago.
What do you think it is from that description?
neb is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 06:48 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
Could be the clutch fork rattling against the cover.
Try repositioning the clutch fork cover..
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 06:51 PM   #3
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
It's the box, my XH T5 did it too, I did more than 50,000k's in that car, 30,000k's with a DEV5, and it didn't change, no worse, no better.
Rick.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 06:59 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
Really , mine doesnt make a noise whatsoever.
13.21 @107.7mph
Old 15-03-2005, 07:20 PM   #5
Thanatos
E-Series Owners Club
Thanatos's Avatar
depending on what the noise sounds like, it could be a majorly worn thrust bearing
Thanatos is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 07:24 PM   #6
Sox
RIP...
Sox's Avatar
Most of mine hadn't either, and I've had a few, thought the XH always had a rattle at idle.
I had 2 different clutches, and had several oil changes, as I said it never got better, though it also never got worse.
It also had a stuffed 2nd gear synchro, though I doubt it's related.
Rick.
Oval Everywhere...
Old 15-03-2005, 07:25 PM   #7
Sox
RIP...
Sox's Avatar
If it's the same noise I had, it won't be the thrust bearing as I had 2 new ones in mine over the time I owned it.
Rick.
Oval Everywhere...
Old 15-03-2005, 07:31 PM   #8
neb
hibernating
neb's Avatar
its not only at idle.. when i'm actually driving i can still hear the noise.. it gets faster with the engine rpm
Old 15-03-2005, 07:32 PM   #9
LUXO_8
windsor user
i was thinking thrust bearing as well..
had one go in the hilux and yeah,, did everything that your's is doin neb
Old 15-03-2005, 07:36 PM   #10
Sox
RIP...
Sox's Avatar
Mine may have done it whilst driving, though I couldn't hear it over engine exhaust noise, road noise etc.
My brother still has the car, I'll take note when I see him next.
Rick.
Oval Everywhere...
Old 15-03-2005, 09:00 PM   #11
neb
hibernating
neb's Avatar
Thanks for your help guys... What I'll do is take it back to where I got the clutch done and see what they say.. Maybe I can blame them and get it fixed for free or at least discounted.
Old 15-03-2005, 09:29 PM   #12
FRDXR6
FRDXR6's Avatar
My mates r31 did that when his gearbox went, as soon as the clutch was let out it made a loud rattling sound
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 09:38 PM   #13
NZ
NZ's Avatar
one thing to check is that the spring that keeps tension in the cable is there. it goes from the pedle to the firewall. My car used to tap like a lifter in an i6 after changing to manual. the spring wasn't there and the clutch fork was rattling against the bellhousing when there was no tension in the cable. it doesnt need much.
i thought it was my engine as well but only realised it wasnt when with even the slightest presure on the clutch pedle while driving the noise stopped.
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 09:42 PM   #14
neb
hibernating
neb's Avatar
Thanks Karl. I'm not sure if it will be that because the rattle seems to match the engine revs.. but I'll check it out anyway.
Old 15-03-2005, 10:35 PM   #15
NZ
NZ's Avatar
i'm even more convinced thats your prob mine matched engine rpm as well.
Old 16-03-2005, 05:41 PM   #16
niko
likes falcon's
niko's Avatar
take it back to where u got clutch done?
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
