05-09-2006, 05:10 PM | #1 | ||
What Wheelspin?
just went out and used some splitters on the sub rca's. sounds no where near as good as it did on the old cd player. WAY less volume. i am running 2 monoblocks which are running two 15's. it also seems that the louder i turn it up, the less volume the sub produce but the more the rest of the speakers produce. what can be causing this???
i tried turning the gain on the amps up but that made it worse. i thought that the sub out on the DVD player was 4v. but when i set the gain on both amps to around 4v its still sounds quiet. even more so actually. WHAT CAN I BE DOIN WRONG???
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
05-09-2006, 05:12 PM | #2 | ||
V8 Ute V8 Boat
try your ground may be that
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
05-09-2006, 05:15 PM | #3 | ||
What Wheelspin?
i'll double check all my earths then
05-09-2006, 06:13 PM | #4 | ||
EF XR6 5spd
when i did mine 1 of the rca's was touchin metal and shorting, causing it to do the same thing you are describing with the volume.
also i think the pre-out voltage is always less than what is quoted in a similar way to the difference between power rms and power max. try askin some 1 on this forum http://www.caraudioaustralia.com/forums/index.php here is a tute on gain setting which i followed http://www.caraudioaustralia.com/for...l=gain+setting |
05-09-2006, 06:50 PM | #5 | ||
EL Fairmont Ghia
on your cross overs.
Try changing one side to either high pass freaquency (HPF) or Low pass freaquency (LPF) and change the other side to off.l This fixed the prob in my mates car.
Me: Jarrod Car: Burgandy EL Fairmont Ghia Tickford options (inlcuding kit and wheels but no f'n LSD) Stage 2 Shift Kit, Lowered, Roof, bla bla bla |
06-09-2006, 06:38 PM | #6 | ||
What Wheelspin?
i have tried ALL of thisand still no luck. no matter what combonation or settings i use, the subs get very quiet above about 50% volume!
HELP GUYS!!! i just spent $1300 on a DVD player and at the moment is sounding worse than my $300 cd player!
06-09-2006, 08:59 PM | #7 | ||
Aspiring mr efxr
are the rear RCA outputs being used? try using rear output insted of the splitter.
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
07-09-2006, 08:11 AM | #8 | ||
What Wheelspin?
i have tried this also. NO LUCK!
07-09-2006, 09:01 PM | #9 | ||
Aspiring mr efxr
hmmm. real head scratcher u got here... call the manufactuer of headunit and/or amps. ask them
07-09-2006, 09:04 PM | #10 | ||
likes falcon's
try a new set of rca's
www.carhubsales.com.au |
